I think I got screwed.
I wouldn't pull a head unless its leaking coolant, just pull the drivers side valve cover and see if its got guide plates or aftermarket rockers. Also a dyno tune may be a good start, or just drive it and build what you want.
BTW post some pics for us
The flowmaster sounds pretty decent imo, but ill still be getting rid of it for a less restricitive option. Not quite sure my route yet, I liked the TSP on my 98 I use to have, so might go that route if I dont do the true duals. The edlebrocks will be going to inplace for pacesetters.
Pyro, I may just take that offer up on ya. Ill let you know after this weekend if I cant find a place to do it up here.
http://img190.imageshack.us/my.php?image=mvi0572.mp4
At the start of the movie you can see the 1000rpm difference between the two tachs.
Get a mechanics stethoscope(harbor freight) and check the alt, ps drive and ac comp. It almost sounds like one of them when they start going bad.
The scope will at least narrow it to the area its in, valve covers, belt drive stuff or main block/oil pan
Hope this helps
Dub
When In Doubt Do Without
Also it sounds like possibly a 383 with a very very small cam. all of the above is IMO
Before you remove the ds valve cover, check the computer and see if it has any tuner info on it, that with the vin go back to the last tuner and see if he still has the profile that would tell you most of what you need to know.
Also I too think you did ok, pics look good, just drive it and enjoy it, as a Z28 that is cool.
Dub
Dub
So is the 30# injectors a good thing? Or do people using go with something else.
Pyro, would a sunday evening work for you by any chance?
Lastly, if for some reason it comes out to be just a 350, is there any legal action I can take agaisnt the dealership? Not that a 350 would be a bad thing, but just under the pretense of false advertisement something like that...
But you might have an early model 95 and it might have the obdI port???
