I think I got screwed.
it's gotta go! Nitrous brackets, tach, red oil pan. I am surprised there is not time slips in the glove box.
Post a pic of your OBD port. It is located under the dash, just to the right of the steering wheel. That way Pyro will know if you need an adapter to connect to his Tunercat cable.
Best of luck with the car, enjoy it.
Mightve put an old image or two in there, sorry if I did. The last two are under the engine, looks like the front cover is leaking oil.
http://img190.imageshack.us/my.php?image=mvi0582.mp4
Easier to pay someone or learn how and do it myself?
To remove the valve cover, its just those 4 center bolts. Look like 1/2in maybe? That and take off the egr pipe so that I can pull the cover off right? Will I be ok to reuse the old gasket for now?
car has a weird idle to idle to it almost like the valve adjustment is off or it's not running on all cylinders
But hey when you get it running right she just might come to life! I vote to keep her and drive the snot out of it!
The motor doesnt feel like its missing or anything if thats whats you mean by cylinders. How do I check the valve adjustment? Figure I can do that when I get the cover off the driver side atleast to see where they are at.
Dont know any circle tracks around here, ill have to call around and see what I can find.
Ill be running the engine without the belt and pulling the valve cover tomorrow if the weather does better today.
