Its finally running
Old May 26, 2009 | 09:40 PM
96Formula6spd's Avatar
Default Its finally running
Well got my car running much better than is was last night. Finally got the LT-4 Hot Cam in. I have two questions. The first one is my oil pressure guauge is not getting any signal. I had replaced the sending unit about 2-3 months ago. Could it be bad or any other ideas. Also when the car is running the check engine light is flashing. Is this normal for a untunned car or should I get it check out?
Here is a link to the car running.
http://www.youtube.com/watch?v=jXuRjMWX9CY
Old May 27, 2009 | 01:18 AM
1eyedmaro's Avatar
You need to hook up a mechanical oil pressure gauge and make sure you have oil pressure first of all. When the cel is flashing that means that there is a misfire. Your car does need to be tuned but it should not be misfiring. You need to hook up a scanner and pull the codes and go from there
Old May 27, 2009 | 08:28 AM
moderate Z28's Avatar
Way to go! Is it me or does your valvetrain sound a little noisy?
Its crazy how the hotcam sounds so different in everyones car.
Heres my vid when I first started mine up - http://www.youtube.com/watch?v=9XI76...e=channel_page
Old May 27, 2009 | 08:46 AM
Badazz 97 TA's Avatar
that engine sounds really weird. rockers sound real noisy. How much preload you running on the lifters/rockers?
Old May 27, 2009 | 11:34 AM
ss.slp.ls1's Avatar
After I put my cam in I adjusted the rockers with the engine off and the valvetrain was really noisy and the car stumbled and back fired when I got on it. I took off the covers and adjusted the rockers again with the car running and it runs perfect now.
While you won't run perfect untuned, you shouldn't be misfiring badly. I would double check your plug wire routing and make sure that all the boots are seated properly.
As mentioned get a tune.
Old May 27, 2009 | 12:11 PM
well i think i might need some plug wires. I have one full turn on the rockers at the moment. My first run was 1/2 turn and I had a really bad tick from cylinder number 1. Dont know if it was the intake or exhaust or both. I herd from someone else that is could be a misfire or what sounds like a really bad exhaust leak.
Old May 27, 2009 | 12:20 PM
Also I know I am getting oil pressure due to the fact when i took of my valve covers the rockers had oil on them
Old May 27, 2009 | 12:47 PM
ss.slp.ls1's Avatar
Did you adjust them with the engine running or off?
Old May 27, 2009 | 12:49 PM
the car was off
Old May 27, 2009 | 12:51 PM
ss.slp.ls1's Avatar
the car was off
Readjust it with the engine running and only use 1/2 turn.
