My Motor is finally complete LE1.6, PICS
Not lately, just got her off jackstands a week or so ago, been through some changes. I've now got a Nitrous Outlet plate sitting behind the TB, along with a chromoly cage, BMR K memberk, and a few other goodies. I've got to tie in my rear brakes (abs delete), mount my Kirkeys, get an alignment, before she's ready for the track...
Honeslty I don't know the specs! haha Llyod and PCMforless does. This is what llyod sent me a while back:
"That is about like a CC 503 as far as duration goes but about .570 lift and a LSA below 110. It still operates from 2000-6300 RPM but has a choppier idle than a CC 503 and will make more mid range TQ and more top end power also."
I'm running the trickflow lt1 heads that flow 253/177 at 0.500" lift and a port matched intake.
the heads are milled to 53cc's to get me 11.5.1 compression ratio.
Please post dyno numbers when you can as I'm about to build almost the exact same motor as yours, I also have the Manley forged lw ft pistons and Scat 6" procomp rods with a stock crank, home ported heads & intake (no flow numbers), Comp custom 230/230 - .560/.560 110 lsa cam, Comp 875 roller lifters (the good ones before they changed the retainer), Comp 1.6 rr's, Rollmaster double roller timing set, CSI ewp, Holley 58mm tb, 42# injectors, coated pacesetter LT's, and a Madz tune. I'm still in the process of gathering parts and getting the money for machine work but I'd at least have a ballpark idea of what kind of power I could expect from my combo.
#33
stock lt1 intake manifold port matched, trickflow elbow, stock maf, slp cold air intake.
#39
No ****. Speed Inc's new setup is gorgeous and includes all new brackets, but I can not see spending $425 on it. I think the setup he has was only $150 when it was made.
