Will these cams fit (94 Z28)?
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
http://cgi.ebay.com/ebaymotors/TPIS-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/SB-CH...1%7C240%3A1318
http://cgi.ebay.com/ebaymotors/SBC-3...4506.m20.l1116
If I can use any of these cams/springs, I will also be using 1.6rr what size push rods do I need?
Most SBC roller cams will work with the 93-94 splined optisparks. I run a ZZ4 cam in my car and have not upgraded the optispark to the later unit. Those cams will not work with the later optisparks due to the dist. runs into the snout of the cam. Although the first cam listed is not a ZZ4 like they are claiming, those are not the specs of the ZZ4(208/221 and 474/510 on a 112lsa). It's probably a regrind of some sort. I picked up decent power with the ZZ4 and a 1.6/1.5 rocker split, lift is .506/.516 with my rockers setup this way. Very mild and smooth idle. Although I would opt to go with the ZZ9(212/226 and 483/520 lift on a 112lsa) out of the two cams.
What size push rods with the 1.6rr and one of these cams?
Also what will be the HP increase using one of these cams with the 1.6 rr?
