1989 vette lt1 swap
so i think you can get it running pretty straightforward, but what are you going to do about the electronic dash? how will you wire all that stuff.
Plus if i recall, the computer on the l98 corvette is on the driver's side and if your wiring harness is from an fbody, then everything will point to the passenger side so you may want to see if you can get a wiring harness for an lt1 corvette as well. while you're at it, might as well upgrade the dash to a lt1 c4 look and get that wiring harness, i think it will look a lot better and a lot of the electronics in that 89 dash are probably suspect as well.
Would be a lot cheaper and probably months quicker to rebuild the L98.
Also would be cheaper and quicker to sell the car he has and buy an LT1 vette.
