high idle
Old Jun 1, 2009 | 01:30 AM
RedRocket350's Avatar
Default high idle
i have a lt1, and i started the car the other day, and out of no where, i had i high irratic idle. I tried to adjust the idle screw down, but the idle did not go down, It is idling at like 1800rpm. I think it is something along the lines of a sensor. Does anyone know, what could be the problem? Thanks in advance
Old Jun 1, 2009 | 01:50 AM
hitmanws6's Avatar
try the TPS sensor and the IAC. those are the 2 most common.
Old Jun 1, 2009 | 02:50 AM
nighthawk15's Avatar
TPS and IAC would be the most likely sensors to cause that, but check for vacuum leaks too.
Old Jun 1, 2009 | 08:54 PM
merim123's Avatar
i had that problem too when i put on my 58mm throttle body on my non bored intake and had all kind of surging / high idle issues. now that i got my motor back together with a ported lt1 manifold and ported for 58mm, it idles fine and no issues.
