ATTN about LPP Header fitment
I felt this deserved it's own thread because it's such an important find. I've been meaning to post this up but now I finally have pics of before and after.
The individual set of headers are *NOT* I repeat *NOT* the problem with clearance issues!
And now you all sit there going
"OK, let's hear it..."And here's the proof:
1st time I installed the headers:
Note that there's TONS of clearance - over an inch - from the headers to the k-frame. The clearance remained when we bolted the k-frame/engine/trans/exhaust into the car.
80 miles later, I spun two bearings, had to drop the engine back out, tear down, and reinstall. But, that's not the point...
I now offer you pictures from the 2nd time the headers were installed, in car pictures (please don't mind how dirty they are):
I have less than 1/8th inch of clearance - on the passenger side it's almost resting right on the k-frame's pinch weld.
Now, I do not know yet what it was that caused this to happen this time around. But, I believe it has everything to do with the rest of the exhaust setup. I had a really difficult time installing the y-pipe because the my y-pipe was welded to the intermediate pipe so I had to disconnect the intermediate pipe just before it goes up and over the axle to the muffler. Unfortunately, I didn't pay attention when the k-frame was out of the car or before putting the y-pipe on... I had such awesome clearance the 1st time that I didn't even think to look after the 2nd install.
I did notice that as I adjusted my y-pipe/intermediate pipe into the pipe that goes to the muffler that my tailpipes significantly adjusted their angle and I have a feeling that this same adjustment is going to significantly affect the clearance of the primaries to the k-frame.
If it's not this, it has to be something else. It's a SIGNIFICANT difference between the first install and the second install. I have a feeling that whatever caused the difference in my case is the same exact reason why there's such a fluctuation of reports on some people who have no problems and others who have a horrible experience with fitment.
My exhaust is currently rattling like a sunovabitch - I think it's hitting the panhard bar and/or axle. But in any case, when I go under the car to fix it I'll definitely update with my findings.
Different heads have different angles on the exhaust banks, causing your headers to mount at a different angle when you install them to the new heads. A small * angle difference at the head can equal a noticable difference all the way down by the flanges.
I have run 3 different sets of heads on my '94... all with the same exhaust, and the exhaust has fit on the car differently every time I changed the heads. Especially when gauging where the collector flanges end up.
Same heads.
The only variables we have are engine & transmission angle, role of the y-pipe and exhaust pulling down on them, and the motor mounts possibly being more forgiving with only 80 miles on them. Otherwise, it's the same exact setup but a huge difference in fitment.
BUT - the main point of my thread was that I highly doubt everyone having issues with the LPP headers is a quality control issue since they're made on the same jig - I think these fluctuations are the result of whatever is causing my fitment issue.
Clearly worn engine mounts play a roll.
Now in order to get the best drive line angles with my 9" rearend, I raised the tranny 1/2" up off the tranny cross member with square washers. This gave me additional right side collector clearance where in the area of the k-member. This is another way to improve the clearance with this problem area.
Same heads.
Everyone jumped on the bandwagon to buy a set when they saw the price, then they all jumped on the bandwagon to bash them when they didn't fit. What some people don't realize is that Kooks, Pacesetter, and just about every other header out there will have horror stories about fitiment issues if you search long enough. But since these headers were in the spotlight, they got bashed more than any other brand.
I think most people were just mad because they spent 1300 on their Kooks setup, or 600 on their Pacesetter when they could have a STAINLESS header for the same price, or half that in the case of the Kooks nutswingers.
I'll stand by them any day of the week and twice on Sundays. I picked up power with these over my Hookers and I can't complain about the stainless either.
LPP's FTMFW
One other way the can shift is up and down due to tolerances in the bolt holes where they bolt to the head. I could shift mine up and down a good 3/4" measured at the collector. This can buy a little of room where it comes close to K-member.
