Porting stock Throttle Body
Old Jun 3, 2009 | 05:28 PM
BizZzatch350's Avatar
Moderator
MTI used to use the stockers for the 52mm. The stock piece isn't bad, rather have it over some of the cheaper after market ones out there. I have a AS&M 54mm on mine.
Old Jun 4, 2009 | 12:21 PM
buffman's Avatar
Originally Posted by 97pontta
You will need at least a milling machine to do the job properly with basic machining knowledge and skills. You need to keep the bores straight and round all the way through the throttle body. You will also have to have the proper sized throttle blades with the proper angle. I do port throttle bodies and I machine new blades from sheet .063 6061-T6 aluminum for the proper blade size. The main advantage with using a bored stock unit is you keep the stock IAC passages.
This man does great work. From Custom jobs to his oil filler necks, always pleased with his stuff
