How much can a lt1 spray stock?
If ur car is a stick you might can get close to this one
why wouldn't I be proud? it's a testament to the LT1s strength (and richness of stock tune) not neccessarily my good judgement, but oh well it went through hell and back then got a cam swap and finally gave out this jan
would need to change the plugs every other month or so though and when I tore apart the motor the pistons all looked perfect still, only problem was the rod bolts stretched on one rod and the bearing got chewed up
And which kit is better wet or dry I'm thinking ZEX 125 wet kit for simplicity and safety?
