which pistons?
Old Jun 5, 2009 | 10:48 AM
97badass's Avatar
Default which pistons?
ok im using 6 inch scat i beam rods. and was going to use the mahle sbc125030f05 pistons. however i got confused since jegs says -5 and summit says +5 any other recommendations for pistons? i havent picked a cam yet but those rods stock crank dart 200cc heads and intake opened for bigger throttle body and 150 wet shot.
Old Jun 5, 2009 | 11:41 AM
95maroz28's Avatar
im using scat i-beams and mahle sbc250030f05 pistons for my build. wonder what the difference is between the ones you have listed. From what ive heard mahle pistons are a good choice unless using alot of spray
Old Jun 5, 2009 | 12:01 PM
97badass's Avatar
doing a quick search on google. . . those are the same piston with a different part number unless i missed one tiny detail but for the most part same thing. i know i need a piston that will hold with spray and high rpms
Old Jun 5, 2009 | 02:38 PM
97badass's Avatar
bump?
Old Jun 6, 2009 | 12:30 AM
97badass's Avatar
ok after searching all day and charging my phone 6 times ive came to conclude i want ross pistons. i found some for a 355 but it says not recommended for boost or nitrous??? so can someone give me the part number for the correct piston? and rings?
Old Jun 6, 2009 | 02:25 AM
97badass's Avatar
i dont need shoes!!!! i just got a new pair of shox!!! i need to know the part number for the correct ross pistons.
