Cam swap parts
Old 08-11-2009, 04:37 PM
ss.slp.ls1's Avatar
Originally Posted by ss.slp.ls1
Felpro SS72861 valve stem seals
Felpro TCS45956 timing cover gasket kit
Felpro MS95580 intake manifold gaskets
Yes, get 7/16" rocker arm studs and get NSA rr's for a 7/16" stud and pick up some guideplates. You might as well get the EWP and DR timing set. Do it once, do it right.
ARP 134-7103 7/16" rocker arm studs
TFS 30400623-8 guideplates
Cloyes 3145 DR timing set is a popular choice.
Originally Posted by gregrob
Thanks Jake. My cam has 5deg of advance ground in so its already set ahead pretty good. I had an adcole profile ran on it to make sure it was right though and its very close to what I spec'd.
Where did you pick up that gasket kit
You can get it at Autozone or Summit.
Old 08-11-2009, 04:55 PM
Badazz 97 TA's Avatar
So what your saying is anyone who doesnt buy a EWP and a DR timing chain while doing a cam swap isnt "Doing it right??"
stfu dude with your do it once do it right bullshit. You DONT need either.
Old 08-11-2009, 04:58 PM
ss.slp.ls1's Avatar
Wow, someone **** in your cereal today?
Never said he needed either, said might as well...
He said he wasn't sure if he wanted to install them. Might as well do it now since he will have the front cover off...
Old 08-11-2009, 05:05 PM
gregrob's Avatar
Thanks for the part numbers SS. I plan on using them.
Old 08-11-2009, 05:06 PM
nik1703's Avatar
LOL if someone **** in my cereal that would ruin my day
Old 08-11-2009, 05:09 PM
no, i had pancakes this morning biotch
Old 08-11-2009, 08:21 PM
z_speedfreak's Avatar
whats up with everyone being ******** to each other this year in the LT1 section? well its def not everyone but theres been a huge increase in attitude this year amongst the LTx guys. chilll people and learn how to respectfully disagree, we're all here to help each other not have e-fights correct?
Old 08-11-2009, 10:16 PM
gregrob's Avatar
Out of my thread ****
Old 08-13-2009, 04:39 AM
gregrob's Avatar
Well guys I ordered the rest of the parts tonight. Tell me if I'm missing anything besides incidentals.. (Oil, Coolant, Shop towels, etc).
1605-16 Comp Ultra Pro Magnum Rocker Arms
134-7103 ARP 7/16" Rocker Studs
103 Comp Cam Installation Lube
249-4605 Comp Cam locking plate and bolts
TFS-30400623-8 Trick Flow Hardened Guideplates
FEL-SS72861 Fel-Pro Valve Stem Seals
FEL-MS95580 Fel-Pro Intake Manifold Gasket
FEL-TCS45956 Fel-Pro Timing Cover Gasket Kit
LCT-37421 Loctite 271 High Strength Red thread locking compound
LCT-40463 Loctite RTV Black Gasket Maker Power Can
10128485 Gm Timing Chain
Previously Purchased
Custom XFI Comp Cam
Patriot 8401 BSBC LT1-Specific Dual Gold Valvespring kit
A/C Delete Pulley
LS1 Lid Setup
All this will be going in at the same time. And a N2O Outlet Plate kit will follow shortly thereafter. Had a nos progressive kit I was gonna put on it but sold that tonight and going to just buy the full kit from n20 outlet and most likely a mallory box to use as a window switch and timing retard.
Old 08-13-2009, 11:41 AM
ss.slp.ls1's Avatar
Custom XFI Comp Cam
A/C Delete Pulley
LS1 Lid Setup
You should be getting a whole new timing set, not just a new chain.
I'm assuming you have an adjustable pushrod and either a solid lifter or a test spring to measure your pushrod length.
What cam are you installing?
Old 08-13-2009, 05:10 PM
JAKEJR's Avatar
Problem wasn't with the camshaft, itself, but with the engine. Karl Ellwein tried two different timing chain/belt setups (one being a Jesel) and two different camshafts and each cam degreed in 8 degrees advances using dot to dot.
He ended up having to use a 6 degree bushing in the RETARD position to bring the cam back into close to the recommended install spec. I have a link to his site if you'd like to read up on all he went through.
I bought my timing chain cover gasket kit from Summit Racing, but I see you've already ordered one.
Sorry for not seeing your question sooner. I'm not getting notified of new responses; what's up with that??
Jake
West Point ROCKS!
Old 08-13-2009, 10:50 PM
  #32
gregrob's Avatar
My buddy has a checking pushrod but I dont have a solid lifter or a test spring.
Those are necessary? I was going to measure just with the stock lifters pumped up
Thanks for the info Jake
Old 08-13-2009, 10:52 PM
  #33
gregrob's Avatar
Oh and the cam is a custom grind using XFI lobes. I dont want to tell all but the duration is really small compared to what most people run but we still ended up w .565 lift.
It will increase DCR like mad which is one thing I need at my altitude.
Old 08-14-2009, 12:33 AM
  #34
ss.slp.ls1's Avatar
Yes, you need either a test spring or a solid lifter to get an accurate pushrod measurment.
Old 08-14-2009, 02:00 AM
  #35
gregrob's Avatar
Wheres a link to the procedure using the test spring?
Old 08-14-2009, 02:10 PM
  #36
JAKEJR's Avatar
My ACE Hardware has an assortment of light springs and I'm sure one of them can be used as a checking spring.
Jake
West Point ROCKS!
Old 08-14-2009, 02:17 PM
  #37
JAKEJR's Avatar
I'm not on the Bigger Is Better Bandwagon either.
Jake
West Point ROCKS!
Old 08-18-2009, 01:31 AM
  #38
gregrob's Avatar
Well some more parts showed up from Jeg's today. The pile is growing:
Quick Reply: Cam swap parts
