exhaust rattle
Old Jun 8, 2009 | 09:52 AM
onebadredz28's Avatar
Default exhaust rattle
hey everyone lately when ive been going after a stoplight i can here a pretty loud rattle under the car. Its seems to be getting worse. It doesnt happen all the time tho just when leaving a stop light. I just had new exhaust manifold gaskets put in but its still there. I heard it might be the catalytic converter because as its original on a 125k mile LT1 car. Let me know what you think. Thanks!
Old Jun 8, 2009 | 09:59 AM
dkishton1486's Avatar
I have a rattle from my exhaust also but I think my y-pipe is hitting my frame somewhere. It started after I did my headers and cat delete. No matter how hard I try I cant get it to go away. Plus now with my solid motor mounts ...wow
Old Jun 8, 2009 | 10:03 AM
93TAJ.C.'s Avatar
Your brick in your cat has broken away from the cat. Basically its just rattling around in there and breaking up, the longer it goes the more breaks off, the moree it will rattle. Mine did it, so i cut the cat open cleaned all the ceramic out and welded it shut. The exhaust will sound a bit more aggressive too.
I hope you have a 1993 car. 1994-1997 lt1's had two cats and you cant get to them as easy.
Old Jun 8, 2009 | 10:24 AM
kinglt-1's Avatar
Yea most likely it is the cat(s) coming apart, but I would not recommend gutting them and leaving it that way. The cat(s) being gutted will actually screw witht the flow since the exhaust is now entering a hollow cavity and getting pushed back into the pipe. I have seen a few cases where this can cost you power over straight pipes being welded in, let alone the added exhaust drone you will get from the exhaust bouncing around in the cat(s).
Old Jun 8, 2009 | 10:39 AM
93TAJ.C.'s Avatar
That may be true for the dual cat lt1's, but I had to do it to mine, and noticed a huge power gain because of how much the cat was plugging the exhaust. I also had no exhaust drone and it gave it an awsome tone, im sure a straight pipe would have been ideal, but this was a whole lot easier and dident cost a penny. I have lt's and ory now too, so thats all gone.
Old Jun 8, 2009 | 11:15 AM
lt1srule's Avatar
or the cat cover..
Old Jun 8, 2009 | 12:33 PM
ss.slp.ls1's Avatar
I got a nasty rattle when my PS y-pipe cracked down the middle when I scrapped over a speed bump. It was intermittent, but really annoying. Got it welded and all was well.
Old Jun 8, 2009 | 12:35 PM
hitmanws6's Avatar
mine did that, turns out the y pipe was banging the tunnel brace
Old Jun 8, 2009 | 12:40 PM
ss.slp.ls1's Avatar
Just throw it away, I did.
Now I have a Spohn tunnel mount adj TA in place of it.
Old Jun 8, 2009 | 01:00 PM
creepingdeath94's Avatar
Agreed...it is probably the pipe hitting the brace under there. If you don't want to throw it out, you can try and space it off the body some. That is of course if it is in fact the brace hitting the pipe and not the cat coming apart. I would get under the car and look at how close the pipe is to everything all the way down line from the manifolds first before chopping up what could be a perfectly fine cat.
Old Jun 8, 2009 | 01:27 PM
ya i have a feeling its my y pipe because when i back in my driveway next to the house it sounds like its coming from by the front wheels. Prolly something little but im going to have my exhaust guy look at it on the lft and see. thanks for the info everyone!
Old Jun 8, 2009 | 02:13 PM
meissenation's Avatar
Can also check your o2s. Mine were loose and would rattle on acceleration but once it got up to 3rd gear it'd go away.
Old Jun 8, 2009 | 02:14 PM
ss.slp.ls1's Avatar
Same thing happened to me once, lol, quick fix though.
Old Jun 8, 2009 | 02:48 PM
if only it were always that easy.
Old Jun 9, 2009 | 05:17 AM
mj114679's Avatar
i have a 95 and i had one cat.... till i deleted it...
Sounds AWESOME!!! lol
Old Jun 9, 2009 | 04:16 PM
TasTe_GOOD's Avatar
I used to have a bad rattle sound coming from my cat area at stop lights and stops. That is until I swapped my sagging motor mounts to new poly ones, then it went away. Your mounts could be sagging w/125k on them. Btw I thought I had a F'd-up cat, too.
