new dyno #'s
it's never enough man no matter how good it does..you know that
thanks for the props
thanks
top end wise...some day
some worked AFR or TFS heads & carb style intake
I think the car would make some really killer power with the above. This will be awhile since I want to work on some interior stuff and N20 setup.
Harold
info from GMHTP article
http://www.gmhightechperformance.com..._rear_end.html
Hey I have a 383 with TFS heads that flow at 307 .600 lift with a HR bigger cam
24X/25X on 108 LSA with .606 lift , I got an LT4 intake with all supporting mods. I am not making that much more power than you are we are actually pretty close. My compression is 11:0:1 set up for a big shot but no timing is taken out yet.
I noticed your compression is quite a bit higher. I would be pretty happy with your setup. Is my compression really hurting me that bad? I know nitrous loves compression but should I have gone a lil more aggressive?
This is due to the RPM dropping back down for sec. when it locks up.
Good luck Sunday...maybe next time I can make it out for some motor runs too...
That's probibly the only chance I have
