ls1 brake upgrade
Old Jun 14, 2009 | 01:29 PM
aajj1987's Avatar
Default ls1 brake upgrade
to do the brake caliper upgrade on a 93 trans am all i need is the calipers and bolts to go to 2 piston calipers right? or is there something else i need?
Old Jun 14, 2009 | 01:59 PM
97Z28SS's Avatar
I think you need the entire LS1 front spindles, calipers and rotors in order to do the swap I believe.
Old Jun 14, 2009 | 02:15 PM
96lt1m6's Avatar
Spindle
rotors
calipers
brake lines from caliper to frame
brake line bracket
98-02 f-body
you will spend up to 200.00 but its worth every penny IMO
Old Jun 15, 2009 | 01:00 AM
Cross's Avatar
Originally Posted by 96lt1m6
Spindle
rotors
calipers
brake line bracket
98-02 f-body
I have done it 3 times and you can use the LT Brake lines it will not make a difference they both will be tight, the LS1's are actually a little tighter hints why I stick with the LT1's.
But yes 200 is about what you will need. If your close my extra set comes with drilled and slotted rotors.
Old Jun 15, 2009 | 01:08 AM
SoxXpupPeT's Avatar
spindles, calipers, rotors, hoses.
you can find sets for cheap on ebay. or you can just modify your stock spindles and get C5 brakes best upgrade bar none
Old Jun 15, 2009 | 02:50 AM
infinitebird's Avatar
Or you can upgrade to longer braided lines, I did that. I didn't really consider having the lines stretched as a safe way to go.
Old Jun 15, 2009 | 06:45 AM
the_merv's Avatar
I was able to use the LS Caliper Lines..I bolted them in where they connect in the Fender well.
Old Jun 15, 2009 | 07:11 AM
BizZzatch350's Avatar
Moderator
I did the swap on my 93, used the LS1 spindles, new wheel hubs, all new wheel hub mounting hard ware, power slot rotors, Hawk Ceramic pads and a Kore3 brake link kit. I changed every thing but wanted to get it done right the first time.
Old Jun 15, 2009 | 09:38 AM
1993 z28 f1's Avatar
Hey:
If you go c5 you really don't need new spindles, you can trim your 93 spindles to accept the c5 bracket like UMI sells. You can find used c5 calipers/rotors on ebay, or get new c5 brembo or powerstop rotors. Just make sure you put them on the correct side as c5 rotors are directional.
IMHO way better than a ls1 upgrade, for just a little more, if you shop around, and oh by the way Z06 rotors are painted red and not that much diff for the price, just paint the normal c5 ones whatever color you want (red maybe) and make sure you loctite that stuff real good whatever you go with.
Dub
When In Doubt Do Without
Old Jun 15, 2009 | 10:26 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Don't you need larger wheels than stock with the C5 or Z06 upgrade? I want to do my brakes, preferably C5 or better, but I'm not sure where to begin.
Old Jun 15, 2009 | 02:09 PM
yes you need 17 or larger wheels for the C5 brakes.
Old Jun 15, 2009 | 02:21 PM
litch2004's Avatar
So if you plan on running 15" wheels these are not an option. The c5 brakes that is
Old Jun 15, 2009 | 07:11 PM
the_merv's Avatar
Probably..I have seen some of the Vette guys use a 16" front skinny.
Old Jun 15, 2009 | 07:35 PM
litch2004's Avatar
do they make greg welds in 16"
