picking up lt1 compression
Just wanting input on how to finish the build, should i mill the heads down? Would i be safe to add boost? I want to make the max power possible. Without swapping the pistons. Let me know what you think, my best bet would be. i dont mind running octane boost and 94. thanks in advance.
Also i will be running a ported super vic "e" manifold with the nitrous works elbow, has anyone had any exp with the msd pro billet distributor, i dont mind cutting a hole in the cowl/dash. or would it be better to stick with the opti?
