Couple of Questions...Help please!
Old Jun 18, 2009 | 08:20 PM
Z28Camaro30Ann's Avatar
Default Couple of Questions...Help please!
Question number one: What is the stock fuel pressure for a 97 LT1??? I just installed a Fuel Pressure Gauge, and mine is running 47-49 lbs right now. Is that normal or no?
Also, I have AFR heads...would it be better to go with ARP Head Bolts, or the stock T-T-Y Head Bolts???
Old Jun 18, 2009 | 08:26 PM
LT1's Avatar
LT1
Stock fuel pressure is 43.5psi
Seems like your fuel pressure is high to me.
Should be around 41-47psi
Old Jun 18, 2009 | 08:32 PM
I know I have an adj, fuel pressure regulator on it, but I have no idea what it is set at...apparently around 48...is it bad to run such high FP with my setup, or is it ok?
Old Jun 18, 2009 | 08:36 PM
dlk1950's Avatar
Mine is at 48 since last fall,,,seems to be fine. nice looking car you got there.
Old Jun 18, 2009 | 08:41 PM
Thanks! That sounds good to me...as long as I dont end up with washed out cylinders or something lol.
Old Jun 18, 2009 | 10:06 PM
Now how about that head bolts question....anyone know???
Old Jun 18, 2009 | 11:19 PM
myltwon's Avatar
best thing to do is put it on a dyno or get a wideband, a real A/F ratio reading will tell you more than a fuel pressure # as far as what is rich or lean for your setup
FYI stock fuel pressure is 40~ psi at idle and 43~ psi at WOT
Old Jun 18, 2009 | 11:26 PM
I run 47 at idle and 49 wot.
I am gettign a wideband next week...
Old Jun 19, 2009 | 02:27 AM
koolaid_kid's Avatar
First, I prefer to run ARP head bolts. They can be re-used, whereas the TTY bolts must be replaced each time.
Second, altering the fuel pressure changes the output of the injectors, artifically increasing their size. IIRC, your 97 should have 24# injectors stock. The equation to use (borrowed from RC Engineering):
New_Flow_Rate = Old_Flow_Rate x sqrt(new_pressure/old_pressure)
[sqrt stands for square root. You probably knew that, but I just wanted to be complete.]
So, the equation would be:
New_Flow_Rate = 24# x sqrt(48/43.5) = 25.2#
Not really a significant amount, but if you were to increase it to LS1 pressure (58 psi) they would now flow 27.7#, which is a significant difference.
Unless you were needing to change the injector size in this manner, I don't really see what it will gain you by altering the pressure from stock.
Old Jun 19, 2009 | 06:49 PM
not trying to alter the FP...I WAS gonna get 30# SVO injectors for her, but I dont have that much power. Ill be between 400 and 500 when I'm done and stocks will be fine for that. I just wanna make sure my pressure is ok or not so I dont end up with problems...I think I am good with 25.2# for now lol. If I ever decide to supercharge it then I will worry about higher flow injectors and all...till then, im content...
