gauge install
also can i tap into the factory temp sensor wire to get my reading for my gauge or do i have to use the sending unit ?? i cant find the plug on the passenger side to screw the sending unit into IF SOMEONE HAS A PICTURE PLEASE POST IT
the only thing i could find on ls1tech about installing the sending unit for the boost gauge was in the brake booster line is that correct ?
for my bypass valve do i just run a hose from the bpv to the driver side of the intake ??
You can also run your bypass valve and boost gauge off of the same source, just T the line.
