Anyone know how to reprogram ECM??
Old Jun 22, 2009 | 06:25 PM
formula1785's Avatar
Default Anyone know how to reprogram ECM??
trying to see if i can reprogram it and see if idle will go down at first start ups..ive scanned and use live data put everything seems to be fine..wondering if ECM is messing up..
Old Jun 22, 2009 | 07:04 PM
ss.slp.ls1's Avatar
How did you eliminate the TPS, IAC, TB, vacuum leaks, etc?
Old Jun 23, 2009 | 03:25 PM
yea everything seems to be working fine at this time..just at about cold starts it will idle higher than normal..
anything else i should check??
Old Jun 23, 2009 | 03:41 PM
ss.slp.ls1's Avatar
How high? It's usually normal for the idle to be high on a cold start and settle back down after a few mins. If it was excessively high, bad temp sensor in the WP maybe?
Old Jun 23, 2009 | 04:21 PM
shbox's Avatar
Providing some idea of what computer you have would help.
Old Jun 23, 2009 | 05:06 PM
bout 1100 and it will go normal then when i go to a street light or stop the rest of the way it will idle high..not going down..only bout the second start up it will..idle normal..and i checked the tem sensor and its working..i know it works with the pcm to provide how cold it is for the air fuel mixture..ill get the PCM numbers soon
Old Jun 24, 2009 | 02:59 PM
got the ECM part number...to let you know that this ECM has over 200 hundred thousand miles on it..wanted to see if i can get a use one and switch them see how it works and if it fixes my idle problem..thats where im at..anyone see if you can find me one while look..not too expensive... 88961150
Old Jun 24, 2009 | 04:03 PM
ss.slp.ls1's Avatar
I'd check for vacuum leaks and I'd look at your IAC counts. You said the idle goes up at a stop, that usually indicates vacuum issues. I wouldn't be too hasty to swap your ECM...
Old Jun 24, 2009 | 10:29 PM
Chevyguy358's Avatar
^-ss def. has this covered
however if you do in fact do have a bad PCM get one from Orilley's (limetime warranty), I found this out after just replacing mine when it locked up during a Tunercat tune upload. I even got a pricematch with AZ's price $115, as far as I know Oreilley's is the only place with a lifetime warranty. AZ, Advance, Nappa and I belive Carquest are only one year, and I believe GM's is a one day (or so I've been told)
