Adding Mechanical Coolant Temp Gauge...HELP
Old Jun 24, 2009 | 10:23 AM
Formulized94's Avatar
Default Adding Mechanical Coolant Temp Gauge...HELP
I am adding a mechanical coolant temp gauge to a 1997 LT1. I have good access to the plug that is in the passenger side head. However, it looks like you could stick a 3/8" ratchet in it and crank it out like on a rear end fill plug. That is not the case. The 3/8" ratchet is too big and a 1/4" ratchet is too small.
Is there a socket set I can buy to get this plug out?
Thanks,
Ryan
Old Jun 24, 2009 | 10:40 AM
shbox's Avatar
It's a 5/16 square drive.
Old Jun 24, 2009 | 10:44 AM
thank you sir.
Old Jun 24, 2009 | 11:45 AM
That socket is proving difficult to find...
Old Jun 24, 2009 | 12:39 PM
shbox's Avatar
You could try a quality piece of 5/16" square stock in a 5/16, 8 point socket.
Old Jun 24, 2009 | 02:38 PM
Just picked some square stock up...I think it is going to work good.
Old Jun 24, 2009 | 09:11 PM
It worked out like a champ. Thanks
Old Jun 25, 2009 | 08:12 PM
Razor_Blade's Avatar
Good post. I just had the same problem.
Old Jun 25, 2009 | 09:29 PM
shbox's Avatar
Old Aug 6, 2009 | 08:41 PM
integraxtc's Avatar
so this plug is on the passenger side head, just the opposite of the ect sensor on the driver side head??
What thread and pitch is the adapter needed for this?
Old Aug 6, 2009 | 10:20 PM
shbox's Avatar
It's near the rear, since the heads can be used on either side.
3/8-18 pipe thread.
Old Aug 7, 2009 | 01:07 AM
integraxtc's Avatar
yeah, between #6 and #8. I felt down there, but I didn't feel any plug. I did feel a "hole" w/ possible threads, but it was nowhere near as big as the one on the driver side.
What gives? I definitely didn't feel a square plug.
Old Sep 15, 2009 | 04:24 PM
integraxtc's Avatar
SHBOX can you tell me which Autometer adapter I need so I can hook up my sensor to the passenger cylinder head.
Autometer atm-2263
atm-2271
atm-2370
