Have any of you done this?
Old Jun 24, 2009 | 08:46 PM
MeanGreen's Avatar
Default Have any of you done this?
Have any of you converted to the LS1 PCM on your LT1? There is a company (EFIConnection.com) that sells the conversions for it. Just wondering since I have never seen that before.
Old Jun 24, 2009 | 08:51 PM
DaveH71's Avatar
not saying its a bad idea or anything but what would be the benefit?
Old Jun 24, 2009 | 08:55 PM
transmaro93's Avatar
dont know if its true but iv been told that the lt1 computer cant handle high rpms...
Old Jun 24, 2009 | 09:03 PM
ss.slp.ls1's Avatar
You'd have a higher rpm limit.
You'd also have the benefit of using EFI live, HP Tuners, or similar tuning software.
There was a thread a while back about coverting to the LS1 PCM and coil pack system. It's not cheap.
Old Jun 24, 2009 | 09:05 PM
MeanGreen's Avatar
That you don't have to worry about the opti taking a crap and that you can tune your LT1 with LS1 Edit, HP Tuners or any similar device by making the change of PCM's. I was searching there website and it looks bad a** what they did with the red Trans Am.
Old Jun 24, 2009 | 09:56 PM
myltwon's Avatar
LS1 tuning software is much more indepth
would you be able to retain the opti with the ls1 pcm?
Old Jun 24, 2009 | 10:32 PM
1badzee's Avatar
That would be cool if I could keep my opti..
Old Jun 24, 2009 | 10:43 PM
ws6manny's Avatar
I believe it comes with a cam sensor that goes in place of the opti
Old Jun 24, 2009 | 11:10 PM
Purple95Z28's Avatar
Are you kidding me? lol. That's the other primary reason for doing this swap.
Old Jun 24, 2009 | 11:27 PM
MeanGreen's Avatar
Why would you want the opti if its one of the primary problems of the LT1's?
Old Jun 24, 2009 | 11:32 PM
riceburnerZ28's Avatar
I wanna hear more about this.. Whats the cost to do the conversion?
Old Jun 24, 2009 | 11:34 PM
It's liek $525 for the physical parts for the swap and $850+ for a complete plug and play wiring harness, then you need the LS1 coil set up too... Big money for the swap but it would definitely be worth it on a highly modded car.
Old Jun 25, 2009 | 12:22 AM
damn for the price it might be better to do a ls swap instead !
Old Jun 25, 2009 | 12:25 AM
great421's Avatar
And, as an added benefit, an LS1's PCM is 'fast' enough to allow you to run a "dry" N2O MAF kit without the fear of getting a dreaded lean spike.
Just a thought...
Old Jun 25, 2009 | 04:04 PM
myltwon's Avatar
because I and many of my friends have had little to no opti problems so don't fix what isn't broken
it's only a "primary problem of the LT1" because people are quick to use it as a scapegoat for any performance or reliability problem
seems like megasquirt would be cheaper/easier
Old Jun 25, 2009 | 05:18 PM
I8ASaleen's Avatar
^ What this guy said.
Old Jun 25, 2009 | 05:49 PM
ss.slp.ls1's Avatar
That would be a much better idea...
One of the fastest cars I know is a '97 SS vert with a LS1/TH400 swap (stock untouched bottom end, ported LS6 heads, single plane, elbow, 100mm TB, huge cam, open LT headers, n2o, weight reduction, full cage, full suspension, ~4000 stall, 12 bolt) runs 9's consistently, and he can still drive it to run errands, lol. I almost cry everytime I see his SS hood clearanced on the underside for the single plan & elbow though.
Old Jun 25, 2009 | 08:00 PM
myltwon's Avatar
Pretty much I'd have to blow up like 5-6 optis for this thing to pay for itself
I have zero opti problems and make peak power well below 7100rpm, not for me
Old Jun 25, 2009 | 09:11 PM
93M6Formula's Avatar
It would be a good idea if u wanted to spend the cash but so far my opti has been good to me(crosses fingers)
Old Jun 25, 2009 | 09:14 PM
myltwon's Avatar
I can't imagine megasquirt is anywhere near this much
