lt1 computer swap
Old Jun 25, 2009 | 08:18 PM
scott94z's Avatar
Default lt1 computer swap
has anyone ever removed the 93 ecu and installed a pcm out of a 94 lt1 camaro?
Old Jun 25, 2009 | 09:27 PM
shbox's Avatar
You would have to swap the whole engine harness as well and add a MAF. There would be some circuits that you would need to research to get connected into the new harness, too. It's not totally plug and play.
Old Jun 26, 2009 | 08:32 AM
WS Sick's Avatar
If you have tunercat or LT1 edit you can run the car in SD mode so to stave off the need for the MAF immediately. Also if its a 95 up harness you use you'll need a diff coil. Although the plugs under the dash will all fit together the wiring is not straight through.
