Help, can't get balancer hub off.
Ok, so I sold my entire set up and I really need to get the cam out to send to this guy.
I cannot get the balancer hub off. I did exactly what they said to do in the Haynes manual and it ended up breaking 3 bolts on the puller.
What did you guys all do?
You need a smaller bolt to go in the crank hole or use the stock bolt and just loosen it a little bit then push on it. Right now you are probably pulling on the hub, assuming you are trying to get the hub and balancer off. Give me a call tomorrow after 1pm if you need any help and I can explain it better if you need.
If you want to make your life easier, buy a harmonic balancer/hub removal/installation tool. It's such a priceless shop tool. You can pick them up for around $50- $70.
As mentioned, you're likely pushing on the hub. and not the crank snout. Obviously the puller will break far before the hub.
THe balancer is already off, that was easy, now the hub is just on there. Thanks for the info guys, I'm gonna try some of that when I get off work tonight.
Skinnies, I might give ya a call later tonight, I work from 12-8 today.
I would also recommend that you put a washer on the bolt going into the threads to keep it straight and put a socket on the end of the bolt that the puller pushed on to keep it from going skwerrly on you.
