having some issues with my camaro
Old Jun 29, 2009 | 07:46 PM
Bad_tx_Z28's Avatar
Default having some issues with my camaro
Well i was driving down the highway the other day and i was about to pass someone. I pressed on the gas and kicked in the passing gear then all of a sudden the car started studdering real bad. I would let of the gas and it would be ok. I had put some 93 oct. gas in it before i got on the highway as well. when i parked the car, i let it sit for a little bit. I came back and it was fine for about 15 mins and then it started again. Later that evening it went into opend loop and it began to run fine. I have no idea what the hell is going on. Any ideas fellas?
Old Jun 29, 2009 | 08:01 PM
ss.slp.ls1's Avatar
Any codes?
Old Jun 29, 2009 | 08:03 PM
hitmanws6's Avatar
mine used to to that because of bad plugs/opti
Old Jun 29, 2009 | 08:08 PM
Bad_tx_Z28's Avatar
no i dont have a way to pull codes. I dont think its the plugs, they are only a year old. Im not sure about the opti though. Im kinda afraid thats what it might be.
Old Jun 29, 2009 | 08:09 PM
hitmanws6's Avatar
do you have to floor it to get it going?
Old Jun 29, 2009 | 08:13 PM
94Z396's Avatar
it may be a bad plug wire or opti? I look at those to issues first.
Old Jun 29, 2009 | 11:09 PM
WhiteThunderZ28's Avatar
From: Your girls house, she is on my "D", Wisconsin
Sounds like the same problem I have... Turns out to bethat mine has the Hi-Res Signal (threw the SES light and had it scanned) to the Opticrap in which is the optical unit itself... I'm bought a new unit, I'll let you know
Old Jun 29, 2009 | 11:12 PM
xxRONNIExx's Avatar
Same problem Im having now. Took it to the dealership they found no codes. Told me to try replacing the plugs and wired so Im in the middle of that now. I hope it fixes it because this job is kickin my @ss:bang
Old Jun 30, 2009 | 07:39 AM
Bad_tx_Z28's Avatar
keep me updated on your probs guys. As soon as i get of work today im going to start chasing them down.
