Need some advice
z28 with 100k miles. Some suspention mods but nothing
serious and the motor is mostly stock.
i dont know much about cams but im reading alot and
trying to learn so bare with me.
someone recomended a CC503, Comp 918 springs,
Comp 7/16 Pro Mag 1.6 NSA rr's, ARP 7/16 rocker arm studs,
TF guideplates, TF chromemoly pushrods.
would this be a good setup and is there anything els i need to
make this setup work.
thanks
thanks
As stated, a new timing set is a good idea.
Are you M6 or A4?
If A4 you will benefit a lot from a 3000+ stall and 3.73 gears.
If M6, 4.10's will make a big difference.
and i will look into getting a timing set and stall aswell.
ss.spl.ls1.
how much power did this setup make over stock.
also how much did all of these parts cost you.
thanks
Comp Cam (CC503) $303
Comp 7/16" NSA Pro Mags $290
ARP 7/16" rocker arm studs $40
Trickflow guideplates $16
Trickflow 7.2" chromemoly pushrods $87
Crane 10308 dual valve spring kit $180
That's what I have. The Comp 26918's are a little for for the springs locks and retainers.
'93-'97 crank sprocket: 10128346
'93-'94 cam sprocket: 10128349
'95-'97 cam sprocket: 10206039
chain: 10128485
Yank, Vig, or Edge stalls are the brands I would get. 3000+ stall rating.
I have seen several people recommend the Yank SS3600.
Add 3.73 gears to the stall and cam and your car will be a completely different car...
