bottoem end ?
Old Jul 6, 2009 | 08:56 PM
TravisMcGill2000's Avatar
Default bottoem end ?
i want yall guys advice on this bottem end . speed pro forged pistons .30 over. scat h-beam rods with arp rod bolts. stock crank with arp main cap bolts. everything balanced..... i plan on running stock ported heads, ported intake,le cam with full bolts ons. plus spraying a 150 wet shot.... do you guys think that bottom-end would be good for wat i want... thanks
Old Jul 6, 2009 | 08:59 PM
RamAir95TA's Avatar
Reliability will come in the quality of the machine-work and assembly. That bottom end should stand up to some nice numbers.
Old Jul 6, 2009 | 09:14 PM
Elliott's94Z's Avatar
Exactly...it should withstand 150 just fine.
Old Jul 6, 2009 | 10:14 PM
My95Z's Avatar
I'd ditch the H beams and go for I beams. You'll save close to or over 100 grams (depends on size and brand) and if its a mild bild (<550 hp) its not needed. I would think the speed pros would let go b/f an I beam rod anyway.
Besides that sounds like a good setup.
Old Jul 7, 2009 | 06:30 AM
one more ? should i so with stock ported heads or try the new trickflow head coming out?
Old Jul 7, 2009 | 10:48 AM
I wouldn't waste the $$$$ on the Trickflows. If anything have AI make you up a set
