Sensor Output/Data Sticky
Old Jul 7, 2009 | 02:39 PM
ss.slp.ls1's Avatar
Default Sensor Output/Data Sticky
I think it's time we made a sensor output/data sticky so that when we are troubleshooting problems and have access to a scanner that reads real time data, you'll know what to look for.
Unfortunately I don't know all the information, so I made this post to gather all of it. I'll update the first post with all of the info as we go along...feel free to post updated/new info for me.
Mods - Once all of the data is verified, can you sticky this?
*This assumes stock tuning and OEM GM sensors.
IAC (Idle Air Control)
idle: ~20-40 (hot idle)
cruising and WOT range: ~60-100
TPS (Throttle Position Sensor)
0% throttle: ~.55-.65v "sweet spot"
100% throttle: ~4.7-4.8v (max is 5v)
MAP (Manifold Absolute Pressure)
idle: ~1/3 BAR (~9.3-9.5" Hg)
under load/WOT: ~BAR (~30" Hg)
*note LT1's use a 1 BAR system. BAR (Barometric Pressure) varies with elevation. For this thread, lets assume BAR = 30" Hg.
Timing
idle: ~20
under load/WOT: ~33-35
*note scanner may read a few degrees higher
Knock Sensor (knock retard)
should be zero everywhere if things are working properly
O2 (Oxygen Sensor)
should oscillate between 0-900mV
IAT (Intake Air Temperature)
~110-120*F
MAF (Mass Air Flow)
idle: ~6-10gps (grams per second)
WOT @ 5800rpm: ~240gps
Special thanks to:
infinitebird
shbox
Injuneer
Old Jul 7, 2009 | 05:18 PM
shbox's Avatar
Injuneer (not a member here) has scanner data explanations on his site that might help. Also some good explanations of how some things work.
http://www.injuneer.com/Scanner.html
Old Jul 7, 2009 | 05:45 PM
infinitebird's Avatar
range: 0-160?
ideal idle count: 35-40?
I'd say anything under about 80 or so is fine.
voltage at 0% throttle: ???
voltage at 100% throttle: ???
At idle it will be around 0.5 or slightly higher. At WOT it should be around 4.5.
pressure at idle: ???
pressue under load/WOT: ???
At idle depends on how big of a cam you have. Stock will be around 30-40 at idle, with bigger cams it will be more. At WOT it will be 95-100 (this is for a 1-bar setup).
Timing
Tatal/advance...don't remember what my scanner reads out???
Timing at idle: ???
Timing under load/WOT: ???
Depends on the tune. Stock at idle will be around 20. At WOT it will be around 33-35 but may show higher by a few degrees depending on the scanner (datamaster always shows the timing a few degrees higher than what is tuned).
Knock Retard at idle/under load: ???
Range???
Should be zero everywhere if things are operating properly.
O2 (Oxygen Sensor)
Should oscillate between 0-900mV?
Yes.
Normal reading? Is there a range?
I usually see 110-120 F.
MAF (Mass Air Flow)
Don't remember if my scanner outputs a reading for this or not...
At idle I usually see 10-12 grams per second (stockish setup). At WOT it will depend on various things.
Old Jul 7, 2009 | 06:15 PM
ss.slp.ls1's Avatar
Yes.
Thank you very much. I updated my first post.
P.S. Are the values for the MAP sensor in Hg or kPa?
Old Jul 7, 2009 | 06:24 PM
ss.slp.ls1's Avatar
Reading that now. Looks to be very informtive.
P.S. I also used some info from one of your other posts today about IAC counts and TPS voltage.
Old Jul 7, 2009 | 08:16 PM
airfix's Avatar
For the tps sensor I believe you mean 5V not .5V at wot.
Old Jul 7, 2009 | 08:20 PM
ss.slp.ls1's Avatar
Correct, thanks.
Old Jul 7, 2009 | 09:32 PM
kPA. I find that easier to work with since most tuning programs have the values specified in that and not Hg.
Old Jul 9, 2009 | 12:33 PM
ss.slp.ls1's Avatar
TTT, anyone have any updates/corrections/additions?
