Connectingrod tightening torque question
Old Jul 9, 2009 | 11:12 AM
monster81's Avatar
Question Connectingrod tightening torque question
Whats the required tightening torque for an LT1 engine? ARP recommended 50 ft-lbs with its especial assymbly lube applied to the threads and nut face ! so i already tightened them to 50 ft-lbs, will i be fine with that? just wanted to make sure before i put the pan on.
Old Jul 9, 2009 | 11:20 AM
SS RRR's Avatar
Village Troll
If they are ARP's bolts then you follow ARP's torque specs/recommendation.
Old Jul 9, 2009 | 05:23 PM
leadfoot4's Avatar
I agree.
However, since I just happen to have the factory shop manual next to me, it says, "20 lb/ft plus an additional 55 degrees".
Old Jul 9, 2009 | 06:06 PM
96capricemgr's Avatar
Torque values are dictated by the fastener. The goal is to slightly stretch the fastener, hence the fastener manufacturer is THE one to listen to.
Old Jul 9, 2009 | 07:00 PM
monster81's Avatar
thanx for the info guys, guess ill just leave it as it is @ 50 ft-lbs
Old Jul 10, 2009 | 01:20 AM
NJLT1SS's Avatar
You should probably put them through a few "torque" cycles as the bolt will stretch. Usually torquing down and loosening the bolts 2 to 3 times will get them to stretch to where they need to be. This does however need to be measured with a bolt stretch gague. Call ARP and get their procedure on this, as its VERY critical. If you just torque them down once and leave them, they will FAIL.
20 lb/ft plus an additional 55 degrees" is correct for a NEW factory bolt, as they are torque to yield bolts. Once you torque them down to spec, they are good, but cannot be reused.
Nick
Old Jul 10, 2009 | 07:08 AM
monster81's Avatar
Nick
yes , i torqued each CR bolts to 50 ft-lbs 3 times alternately as it is recommended in the ARP's instructions sheet
Old Jul 10, 2009 | 07:59 AM
shbox's Avatar
Nick
Just because the tightening recommendation uses the torque/angle method, does not necessarily mean the bolts are TTY. The t/a method is a more precise way of ensuring good clamping force. GM used the exact same rod bolts for 93-97 LT1s in the f-body. The earlier years used the straight torque value and later used the t/a method. That would seem to suggest that the bolts are not TTY.
Old Jul 10, 2009 | 08:21 AM
the_merv's Avatar
Veteran: Air Force
My question to the OP is what kind of bolts are you using? Stock or ARP's..?
I had Eagle Rods in my LT1 Build that had ARP Bolts, they required a specific sequence..as well as the ones in my Eagle Rods on my current LS build.
Old Jul 10, 2009 | 05:29 PM
JAKEJR's Avatar
My view is that when it comes to rod bolts - the most heavily stressed fastener in the engine - I don't get creative. I just follow the directions of the bolt manufacturer;
Whatever they say I do, but that's just me.
Jake
West Point ROCKS!
