Old May 26, 2016, 04:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
Fuel Pump Replacement
Old Jul 13, 2009 | 12:31 AM
Crows93Z's Avatar
Merv's right... it's a PITA to get those lines free unless you make that other cut. Unfortunately, I never made that cut and just added an unnecessary 30 minutes to the job the first time.
Old Jul 13, 2009 | 01:05 AM
sdotlog's Avatar
hmm... looking like this is a whole lot easier than to drop the tank. Replacing mines as well. shouldnt be too far off from how its done by you f bods..
Old Jul 13, 2009 | 08:02 AM
the_merv's Avatar
Veteran: Air Force
Yes it is ALOT easier to cut than to drop the Tank. I did that a first time to replace the Fuel Pump with another stock one when it went out on me one day, then I went in there again to change over to a Walbro 255 for my LS Engine. It took about a half-hour to change it. Since then I've taken that Panel off for a few other things, it's a very big help.
Old Jul 30, 2009 | 10:34 AM
meissenation's Avatar
Totally agree with merv- do the "L" shaped cut! Those damn lines took me forever to 'quick disconnect'. Of course we didn't think about cutting a notch until we got one of the lines disconnected and had gas all over - will wait until next time to do it!
Old Jul 30, 2009 | 11:21 AM
2XR95Z28's Avatar
Just curious on the people who used a cut off wheel? was there any problems with the sparks and the gas? thats what made me so nervous when i did mine so i ended up using tin snips and well lets just say its not near as clean of cuts and the pics in here. Is it save to use a cut off wheel say now that i did the pump change over two months ago and the gas that was dripped should be evaporated?
Old Jul 30, 2009 | 01:36 PM
I'd wash down the top of the gas tank, personally, but I think it's safe...
Old Jul 30, 2009 | 01:44 PM
RamAir95TA's Avatar
I used the cutoff wheel in my pictures. Just go slow and take your time. If you go slow enough you won't make any sparks. The tank is sealed so there wouldn't be any vapors to ignite anyway. Don't cut too deep as the lines do lurk underneath.
Old Jul 30, 2009 | 01:50 PM
1badzee's Avatar
Did that too. I just haven't made a cover for mine yet oh well. My interior is removed anyway. I am re-doing everything (wiring, weight reduction, etc) so im riding comando right now..
Old Jul 30, 2009 | 02:41 PM
enjoi355's Avatar
the trap door is the best way, for those looking for a guide http://www.geocities.com/formulapower2/fuelpump.html
and that little notch is not a bad idea either, i didnt do it but wish i wouldve thought of it, lol
Old Aug 29, 2009 | 10:14 AM
Wastedyrs's Avatar
Originally Posted by DopdBrd
At first I was like, , then I thought about it and was like
That is for sure the right way to do it.
So how long did this whole process take.
Old Aug 29, 2009 | 11:02 AM
SoxXpupPeT's Avatar
if you go slow and do everything the proper way. around an hour and a half
Old Aug 29, 2009 | 11:27 AM
  #32
the_merv's Avatar
Veteran: Air Force
Like 45 minutes.. the Dremel cut it like butter..I had to do my job in a hurry cause it was starting to Rain and we were outside at the time. I don't think it looks too bad..
Old Aug 29, 2009 | 02:11 PM
  #33
koolaid_kid's Avatar
I did the "L" like merv recommended. Made the disconnects very accessible. Not a bad mod, easy to access for the next time (gonna need dual pumps for the turbo mod). I used a Dremel, it used a lot of cutting wheels but was quite easy and safe. No way were the fuel lines in danger of being cut.
