Now what????
Today i replaced the Opti, still no fire, getting the same results on the DVOM test.
I don't know what else to replace other than the ICM (can't find a test for it) Crank sensor (checking it now) and the PCM....
frustrated...... (and hot)
Today we are going to check for perfect continuety from the opti plug all the way to the ECM, if all that is good i am going to take apart the brand new opti and look for failure...
Is the car is cranking over?
What brand opti did you use?
Rare chance it could be a VATS issue. Is the security light flashing/on?
Back on topic...you said that your injectors are not firing. Do you have spark? A easy test would be to have someone spray starter fluid into the TB while you are inside cranking it over. If it starts and runs, then you have other issues than ignition.
I have read that it will not, but my local part slingers tell me otherwise. As far as i know the comp and tach both get the rpm's from the cam sensor (opti). Any help?
Your parts slangers probably don't know a lot about LT1's...
