Long tube/steering shaft problem
Old Jul 15, 2009 | 11:03 PM
blkZ28mara's Avatar
Default Long tube/steering shaft problem
My #1 primary on the driver's side is extremely close to the steering shaft. I took the linkage off to get the header on, and even with the linkage off the primary is close and i can't get the linkage back on.
Any pointers? Get creative with a hammer on the primary? Grind the linkage down?
http://photos.streetfire.net/photo/1733430.htm
Old Jul 16, 2009 | 12:12 AM
94maro's Avatar
could be your motor mounts are worn out...
Old Jul 16, 2009 | 12:18 AM
blkZ28mara's Avatar
I thought that might be the problem. The car only has about 48k on the clock, but i then again it is a 14 year old car.
Old Jul 16, 2009 | 01:21 AM
SPEEDYTRANSAM1996's Avatar
what kind of headers are they i had the same problem.I put it on 3/4 of the way and it was hitting till i put it all the way on then it hit a tiny bit so i put a extreamly small dipple in it. I got custom headers though that i bought from a friend.
Old Jul 16, 2009 | 06:13 AM
old93camaro's Avatar
I have the Lpp headers and i just took the shaft off and hit it with some light sand paper.. and make sure you put the shaft in a way that the knuckle is not hitting it but it will work
Old Jul 16, 2009 | 06:51 AM
jayz28's Avatar
I took the knuckle off and grinded on it a little bit. Its pretty strong and there's still enough metal there not to weaken anything.
Old Jul 16, 2009 | 07:42 AM
Nostang's Avatar
You might want to pull the header off and use a round pipe and place it against the header pipe and hit it with a hammer to make clearance. I had to make a slight dent in my primary with my hooker longtubes and it worked great...just enough to clear the shaft. It might take a few tries of fitting but go slowly and only dent it enough to make clearance and not more.
Old Jul 16, 2009 | 07:46 AM
1993 z28 f1's Avatar
Hey:
Loosen the bolts at the firewall for the steering rack, slide it as far as you can towards the middle of the car, and remove the cover from the shaft. If that does not give enough room remove those bolts and slot the holes about a 1/4"-3/8"and that should do it. It will articulate the angle enough to keep the shaft from making contact with the header pipe, don't dent the pipe and no grinding should be required this way. Also new poly trany and motor mounts help with the contact/clearence of the subframe and the headers.
Dub
When In Doubt Do Without
Old Jul 16, 2009 | 08:03 AM
the_merv's Avatar
Veteran: Air Force
LS1 Steering Shaft.
Old Jul 16, 2009 | 10:18 AM
96lt1m6's Avatar
Originally Posted by the_merv
LS1 Steering Shaft.
cant go wrong w/ls1 shaft, more clearance and will improve the steering by getting rid of the rag-joint
Old Jul 16, 2009 | 10:36 AM
SS RRR's Avatar
Village Troll
Those flanges are monsterously thick. What headers are those?
Old Jul 16, 2009 | 10:54 AM
bricez28's Avatar
mine hits and i have pacesetters.
Old Jul 16, 2009 | 09:34 PM
blkZ28mara's Avatar
The headers are the ebay stainless kooks/lpp knockoffs. They fit great other than the steering shaft. I am out of town this week but when i get back ill try to slide the shaft out from the firewall before i grind/dent anything up.
Thank you guys very much for the responses
