coil packs
Old Oct 5, 2009 | 12:20 PM
J2Pharren1's Avatar
Dudez i can haz ls1 intack on my ltwun!!???
Old Oct 5, 2009 | 12:25 PM
ss.slp.ls1's Avatar
It's not an LS1 intake.
Old Oct 5, 2009 | 12:27 PM
the_merv's Avatar
I wouldn't let it get to ya man..it's not bothering me..I know what it is..
Old Oct 5, 2009 | 12:32 PM
ss.slp.ls1's Avatar
I'm not. That's what my face will be when I pop my hood and some one asks me what year LS1 that is. LOL.
Old Oct 5, 2009 | 12:44 PM
illusions's Avatar
Here is a pic of my LTCC setup.
LTCC setup
Only thing that is used from the opti is the optical sensor. The high voltage is removed from the opti. All I have seen is a smoother idle and no longer have spark contamination and misfires in the higher rpms. I mounted the control box inside the truck behind my glovebox to keep it dry.
You can then ditch the stock ICM and coil.
Old Oct 5, 2009 | 12:54 PM
ss.slp.ls1's Avatar
LTCC setup
Very clean.
Old Oct 5, 2009 | 02:28 PM
gregrob's Avatar
Im thinking about the coil pack deal myself. My Dynaspark just died after only 5000 miles. Completely rediculous.
Old Oct 5, 2009 | 04:43 PM
ZachsBlack94Z28's Avatar
LS3 ??????
Old Oct 5, 2009 | 04:52 PM
ss.slp.ls1's Avatar
Originally Posted by ZachsBlack94Z28
LS3 ??????
What makes you say that?
Old Oct 5, 2009 | 04:54 PM
lol I think i got my answer.... nice setup
Old Oct 5, 2009 | 05:01 PM
ss.slp.ls1's Avatar
L76/L92/LQ4...close enough to a LS3...but it's definitely not a LS1.
Old Oct 5, 2009 | 05:13 PM
  #32
transmaro93's Avatar
LTCC setup
what opti are you using with your ltcc??
Old Oct 5, 2009 | 05:18 PM
  #33
illusions's Avatar
i'm using a stock Delphi replacement from the partslady on ebay. mine had gone out so I replaced it then purchased the ltcc months later. Opti is still good. I have noticed I ran pig rich after the ltcc install. I do not know why but that will all be fixed once HCI is done shortly.
Old Oct 5, 2009 | 06:39 PM
  #34
what are you spinning that opti too... im going to replace mine but ill be spinning to probably 6600-6800 and i didnt want to buy a million dollar one becuase im only using it for the trigger... just trying to figure out if the delphi is as good as the delco original...
Old Oct 5, 2009 | 06:56 PM
  #35
ss.slp.ls1's Avatar
I have a stock AC Delco and I spin to 6500 regularly. 6800 on occation...
I was sure to thread lock the rotor screws though.
AFAIK, the Delphi unit is just as good.
Old Oct 5, 2009 | 07:58 PM
  #36
^^ right on... ill give the delphi a shot then becuae its reasonable cheaper... thanks
Old Oct 5, 2009 | 09:32 PM
  #37
the_merv's Avatar
That looks very sharp.
Thanks.
It's the GMPP L76 Intake..pretty much identical to the LS3, just the way the MAP Sensor mounts is the difference. The L76/LS3 Intakes are the only GM Car Intakes that are made for these L92/LS3 Heads, these heads are unique from the majority of the LS Heads cause of the Rectangular Intake Ports. The LS7's are Rectangular aswell, they are different aswell..one of a kind.
Old Oct 5, 2009 | 11:56 PM
  #38
LT1's Avatar
LT1
Thanks.
Does the LS7 heads bolt on to LQ4/LQ9 ?
Old Oct 6, 2009 | 12:39 AM
  #39
ss.slp.ls1's Avatar
I think you need a larger bore to use LS7 heads.
Old Oct 6, 2009 | 06:15 AM
  #40
duh's Avatar
duh
^^ Bingo....the LS7 is the nice and large 4.125" bore. So unless you're that "big" (or close to it) you'll have piston to wall issues. I wish I was that big
