Post pix of your LT1 engine.
Old Aug 13, 2009 | 12:17 AM
  #101
skinnies's Avatar
fuel line relocation mod for one
Old Aug 13, 2009 | 01:13 AM
  #102
WYATT318MOPAR's Avatar
I can actually play this game, wasn't too long before I got into the LS craze that I built this little forged 355 for a C4 that I had. Fully forged Scat bottom end, Speed Pro pistons, Comp custom grind, and a little set of Headmann headers. Was a pretty nice little power plant I just didn't like the car all that much so I moved on
Old Aug 13, 2009 | 06:49 AM
  #103
z28rob18's Avatar
here's the most up to date pic of mine took it last night. figured it looks lik a motor now. its a 385 diamond pistons 11:6.1 220cc trickflow heads custom HR should run real strong wit a 200 shot
Old Aug 13, 2009 | 08:41 AM
  #104
N2OMIKE's Avatar
Still working on it.
Old Aug 13, 2009 | 01:36 PM
  #105
vegasfbody's Avatar
Originally Posted by killagt
wat the different , between before and after pix ? im i missing something ?
moved the fuel lines and tucked some more wires and moved the fuse block and a few other things
Old Aug 13, 2009 | 01:37 PM
  #106
vegasfbody's Avatar
diggin that blue man you get those powdercoated? also you should get that intake elbow blue it would pop for sure
Old Aug 13, 2009 | 01:44 PM
  #107
Nyte96's Avatar
On its way for install
Installed
And currently being PULLED AGAIN
Old Aug 13, 2009 | 03:21 PM
  #108
monster81's Avatar
some good lookin LT1s in here, keep it up
Old Aug 14, 2009 | 06:24 AM
  #109
A20SVT00's Avatar
keep on coming guys bad a.. lt1s
Old Aug 14, 2009 | 07:59 AM
  #110
SS RRR's Avatar
Village Troll
You painted the oil valley?
Old Aug 14, 2009 | 08:02 AM
  #111
z28rob18's Avatar
some ppl prime the valley for theory's that it makes it slicker and easier for the oil to flow.
Old Aug 14, 2009 | 09:18 AM
  #112
duh's Avatar
duh
In addition if you open up the holes at the front and rear of the block (the front feeds the timing chain....nice big 1/2" holes), it helps get the oil back to the pan. I've also seen the vents put in, in the valley....our "spider" for the lifters kinda prevents it, but I'm sure someone could figure it out if they really want to.....
And it is proven to help get the oil back in the pan a little faster.....if it actually helps I couldn't tell you....
Old Aug 14, 2009 | 01:01 PM
  #113
Whyrun's Avatar
I used to use gliptal (spelling) to paint to inside of the case's on our drag bikes. It helped oil retrun and helped to keep the oil from wicking into the cast aluminum.
  #114
AZ2ENVY's Avatar
Originally Posted by DroppedM6Z
miss it everyday....
what happened to your Camaro ?
Old Aug 14, 2009 | 01:14 PM
  #115
Painted and clear coated along with totally deburring the oil galley returns. The faster the oil get back out of the lifter valley the less heat you retain under the intake itself, essentially dropping intake internal temperatures. Old school SBC speed secret now you know, you can also paint the bottom of the actual intake itself to slow the transmission of heat from the oil spraying on the bottom of it.
Old Aug 14, 2009 | 01:15 PM
  #116
Blk99ek's Avatar
Here's mine nothing special :-)
Old Aug 14, 2009 | 01:19 PM
  #117
z28rob18's Avatar
deburring? is that where you plug the holes under where the lifters sit so the oil doesnt drip and hit the crank? that another trick i was told.
Old Aug 14, 2009 | 02:34 PM
  #118
sepno77's Avatar
Old Aug 14, 2009 | 04:47 PM
  #119
duh's Avatar
duh
deburring is removing all the sharp edges, so that oil has a nice smooth path to follow. Another trick instead of painting, I've seen guys grind the entire valley smooth to a fine shine, looks like they polished cast iron.
Old Aug 14, 2009 | 05:31 PM
  #120
djjab57's Avatar
I know its ugly but i wanted to post up one last pic of it before the new set up is finished in 3-4 weeks
