Some CC503 questions
I've been running a 23X 23x with .61X lift on a 110 LSA cam, and promags with stock LT1 knock module for more than a year now with no issues.
http://www.summitracing.com/parts/PH...1/?image=large
Is it true, or is it worth the 30$ insurance?
Mike
Definitely ditch the pacesetter crap gaskets, here are the ones I'm running with no problems, plus they are only $20. Make sure to tighten your header bolts again after the first heat cycle and periodically there after.
Tightening the bolts twice won't be necessary. If I can find the nuts I am looking for that is.
Removing the spark plugs was such a piece of cake, with the manifolds on (I have not touched the exhaust yet but will do tomorrow). I don't know why everyone says its annoying and takes forever to replace. Get yourself some decent tools guys, and you will be able to do anything. Deep socket 5/8, 3/8" drive universal joint and a 3/8" drive ratchet from Snap-on or FACOM. Thats all I ever used, and I have huge hands!
I removed water pump and opti, radiator, condenser, crank pulley, fans, removed the driver side O2 sensor, and stopped at the timing cover which will be dealt with after the exhaust manifolds are off.
I only took 2 pics, will post them soon.
Any tips guys?
Any tips guys?
I removed the rocker arms and pushrods today, intake is off.
I need to source a hub puller, which won't be easy. Any alternative ways to remove it? A pulley puller and some tricks?
-3 jaw-puller
Remove the crank bolt, slip the 4" caliper bolt (like this one: https://pontiworld.com.au/usgmsp/images/boltcaliper.jpg) inside, attach the 3 jaw puller to push against the caliper bolt and pull on each ear of the hub. Done it that way countless number of times, never had a problem.
To reinstall the crank hub, you'll need a hardened threaded 7/16 20 rod, a hardened 7/16 nut, and a few large hardened washers. Thread the rod into the crank, slip the hub onto the rod, slip over a few lubricated washers (large enough to contact the hub properly), screw on the nut and tighten with a wrench until the hub is seated all the way on.
