abs
Old Jul 27, 2009 | 09:24 PM
vegasfbody's Avatar
Default abs
so i see on some cars on here it looks like you guys get rid of the abs disribution block or whatever how do you go about doing that and pros and cons of it??
Old Jul 27, 2009 | 11:15 PM
vegasfbody's Avatar
anyone? have an insight on this???
Old Jul 27, 2009 | 11:48 PM
zlover129's Avatar
run custom lines into a proportioning valve, better braking feel, adjust ability, and better braking overall. You have to run a line from the master to the front lines and then a customer line to the rear with the valve on it, usually sits right under the car where the frame startes to curve up.
Old Jul 28, 2009 | 02:07 PM
C_Rules's Avatar
you can get all the parts to do it or a complete kit from sjm manufacturing.
Old Jul 28, 2009 | 02:14 PM
camar0corey's Avatar
I think on the weight reduction list its 15 lbs. also? Don't remember, its been awhile since I looked.
Old Jul 28, 2009 | 02:30 PM
the_merv's Avatar
Veteran: Air Force
I did it with a 1989 Camaro Brake Block..you can kinda see it in the pic, I'll get on my photobucket later and get the close-up one.
Old Jul 28, 2009 | 04:11 PM
vegasfbody's Avatar
thanks for the responses i was just wondering cause it looks a lot better without it and i just wanted to see if it help the braking or not
Old Jul 28, 2009 | 04:57 PM
the_merv's Avatar
Veteran: Air Force
Here is the close-up. The front ones aren't in cause I had the K-member setup to drop back out.
Old Jul 28, 2009 | 07:57 PM
vegasfbody's Avatar
very nice thanks for the pics i think imma go with that sjm setup
Old Jul 28, 2009 | 08:52 PM
ThreeHonks's Avatar
I made my own kit for about $25
Old Jul 28, 2009 | 09:56 PM
vegasfbody's Avatar
explain?
Old Jul 28, 2009 | 10:04 PM
the_merv's Avatar
Veteran: Air Force
I got about $5 in mine..no ****.
Old Jul 29, 2009 | 01:31 PM
ThreeHonks's Avatar
All you need are a couple brake fittings and a reducer from 1/4" line (for the rear) to 3/16" line and a brake T to split the front brakes
Old Jul 29, 2009 | 02:20 PM
the_merv's Avatar
Veteran: Air Force
I just took it off of the 89 model and used a Flare Tool to adapt it. I had to drill out one of the fittings to run a bigger line.
Works like a charm
Old Jul 29, 2009 | 04:28 PM
vegasfbody's Avatar
say i order the one from sjm do i need 3 or 4 channel whats the diffrence i suck *** with brakes haha
Old Jul 29, 2009 | 04:47 PM
the_merv's Avatar
Veteran: Air Force
What year is your car?
Old Jul 29, 2009 | 04:57 PM
vegasfbody's Avatar
1994 t/a a4
Old Jul 29, 2009 | 05:05 PM
sweetbmxrider's Avatar
does it have traction control? if not, 3 channel
Old Jul 29, 2009 | 05:27 PM
vegasfbody's Avatar
sure does not ok thanks man
Old Jul 29, 2009 | 05:39 PM
the_merv's Avatar
Veteran: Air Force
When did the 4-channel come out?
Take a pic of your Brake Module and post it of you can Vegas..
