? about carb'd ltx.
when i am setting initial timing for this motor, how the FRICK does it work.
Set motor at tdc compression
pull dampener?
align arrow pointing at 12 o clock?
mark this as what in terms of timing?
any help would be appreciated
pull dampener?
I think you would have to mount a timing marker somewhere. Then you'd need a line of some kind on your harmonic balancer. Install the balancer that the line matches up with the 0* mark at TDC. Then you'd have to use a timing light to advance the timing to the "best" setting. What that is I have no idea.
