Miss around 5k RPM's
That's not a bad idea...I'm starting to feel it in the lower rpm range now. I'm gonna check for arching tonight. I have a coil on the way. I'm gonna test the fuel pressure hopefully tomorrow or at least in the next couple days. What's your opinion on MSD plug wires? I'm probably gonna go with those wires, but I'm not sure on spark plugs. I want the NGK's, but I just can't make myself pay that much for plugs lol...What's a cheaper good option for plugs? And I'm probably gonna go with an opti unit from the ebay seller "partsladi"(believe that's right) if my fuel pressure checks out okay...
Waiting on an update from 86formula...thanks
Okay, so I got out there last night and checked it out. I did see some arching out from either the front driver side plug wire or the coil. I couldn't tell as I didn't have a flashlight with me. I got in there this morning after I got off work and moved around the plug wire from the first plug. It almost completely got rid of the miss. Definately getting a new set of wires and probably plugs. Glad I don't have to replace the fuel pump lol...
Another question, where does the plug wire that run around to the back of the engine off the back plug on the driver side run to? Any suggestions on a good set of wires/plugs for cheap? Thanks
Cheap would be Duralast replacements. Take extra care to keep them as far away from the exhaust manifolds as possible. I would get some MSD 8.5mm wires if I were you. I go the extra mile and use Accel heat sleeves at the plugs. Haven't burned a wire since.
Jegs 8.0 wires are only $35 (jegs.com). They seem pretty good, very low resistance. I bought some but haven't put them in yet. I'd go with the NGK plugs, they aren't too expensive and seem to be the best from what i've read.
