wiring harness
Old Aug 5, 2009 | 12:27 PM
97badass's Avatar
Default wiring harness
ok shoebox wheres your instructions for the wiring harness? i took mine off and now i cant remember how exactly it was ran on the motor. or if anyone has pics of their engine wiring or knows where i can find pics of it let me know. also i want to clean up this engine bay
Old Aug 5, 2009 | 12:29 PM
ss.slp.ls1's Avatar
http://shbox.com/1/harness.htm
Old Aug 5, 2009 | 12:31 PM
97badass's Avatar
im looking at that right now. im trying to figure out how it was ran inside the engine bay
Old Aug 5, 2009 | 12:43 PM
ss.slp.ls1's Avatar
The way it is layed out in the pictue is how it should lay out on the engine. The two furthest right strands snake down behind the engine on the drivers side. The strand with the most amount of heat sheilding material drops down the engine bay on the passenger side, down and around the exhaust manfold (on the outside, not in between the manifold and the engine). The lower left bundle of wires goes through the firewall and connects under the dash on the passenger side. Most of the connectors will only plug into the right sensor. Lay it out, take your time, you should get it.
