slp where are you...
Old Aug 7, 2009 | 04:23 PM
97badass's Avatar
Default slp where are you...
ok the motor is for the most part together now except the radiator and the ac condensor. i tried to start it just to hear it start....well all it does is clicks. i checked the tps wires they are plugged in. i tapped on the starter... still clicks. i know the battery is junk but i have the booster connected to it on 200 amp engine start. still jsut clicks. btw the windows work great takes about 1 second to get them all the way down. any other suggestions?
Old Aug 7, 2009 | 05:08 PM
ss.slp.ls1's Avatar
Sounds like you are not getting enough juice to engage the starter or the starter took a dump. You can try and jump the pins in the starter with a large screw driver to see if it engages. If it doesn't, try a new battery/fully recharged battery. Maybe get it tested while you are at it. If that doesn't work, take your starter in to have it tested.
Old Aug 7, 2009 | 05:12 PM
97badass's Avatar
i tried the jumping the starter with a screwdriver i couldnt get to the other post but i got the bottom one and shorted it with the exhaust lots of spark and a clank. so i know the sol. is working... but it didnt spin just clank. i know the flywheel is fine. the car has sat for almost 2 years but when parked everything worked except the tranny and a severe intake leak
are there any other electrical plugs that have to be plugged in? im sure whatever it is im missing is simple to fix.
Old Aug 7, 2009 | 05:20 PM
creepingdeath94's Avatar
Are all the ground straps connected? Clean metal surfaces to connect with...no paint or anything impeding the flow of electricity? I had a case where I didn't get all the paint off of a ground strap wire connection to an accessory bracket I had painted and it did the same thing/tried to ground the starter through the tiny body ground strap on top of the motor to the firewall instead :-p Also, if the battery is totally garf, it may still not start even with the jump battery/start cart.
Old Aug 7, 2009 | 05:26 PM
97badass's Avatar
ok i will get a new battery when i pick my fiance up from work since her 3rd gen is a pos
Old Aug 7, 2009 | 05:29 PM
Not guaranteeing that a new battery will do it, just saying. Especially if you know the battery is junk, you might as well eliminate that variable. I would try and get the starter off and over to the auto store and have it tested while you are there.
Old Aug 7, 2009 | 05:39 PM
97badass's Avatar
ok while we are at it. lets eliminate my next issue... how do you bleed the slave cylinder with it installed in the car? i had to replace mine after i barely pushed on it and it puked all the internals out and bent the little pushrod. now it wont gain pressure with the new one
nevermind... a different search term found what i was looking for on the slave... back off the car for the 454954758437 time
Old Aug 7, 2009 | 05:44 PM
ss.slp.ls1's Avatar
It should be self bleeding. I have heard that you can unbolt it from the bellhousing and hold it so the the end where the hydraulic line connects to it is facing up. The try to pump the slave with the push rod by hand. Then bolt it back up and try to pump the pedal. Try a search to see if you get more on the procedure.
Old Aug 7, 2009 | 06:26 PM
97badass's Avatar
i got it bled... i unbolted it and let it hang and pushed the rod till i could barely push it hurts really bad but worked great i had to fill the resevoir twice in the process now clutch feels really tight again . and off to get the battery and the fiance so i can hear her bitch about me being on ls1tech again
Old Aug 7, 2009 | 08:30 PM
97badass's Avatar
new battery and its alive started right up but unfortunatly it was short lived with another intake manifold leak... i assume.... there is oil on the ground in front of the motor
