Components needed to install nitrous?
Old Aug 7, 2009 | 11:33 PM
litch2004's Avatar
Question Components needed to install nitrous?
after seeing the new nitrous system just released and for the bad *** price i think i might go ahead and throw some on.
I have a full msd ignition system( opti, blaster coil w/ harness, and msd-6AL).
What other components will i need to install for this to function at its full potential. And will the 6AL allow my to incorporate the needed equipment or will i need to buy a different ignition box? Any help will help.
Old Aug 8, 2009 | 10:19 AM
litch2004's Avatar
bump ttt
Old Aug 8, 2009 | 06:37 PM
litch2004's Avatar
no one knows?
Old Aug 9, 2009 | 09:32 PM
litch2004's Avatar
bump t t t
Old Aug 9, 2009 | 10:52 PM
I8ASaleen's Avatar
The 6AL should be just fine, I would pick up a window switch for the kit as well so you can make the N20 come on only when needed at WOT. How much shot are you planning on running? A 100 shot should be just fine on the stock fuel system, but if you go any higher I would run a 255lph fuel pump and maybe even look into bigger injectors/tune.
Old Aug 9, 2009 | 11:22 PM
litch2004's Avatar
So there window switch will work well with the 6AL? Im not to familiar with what all it takes to install the system. If i do buy one it will be the new kit that jsut came out. Im waiting to hear back from a PM to see what size shots come in the kit.
I am already planning on getting 36lb injectors and my fuel pump maybe has 3000 miles one in but kinda planned on getting a 255lph anyways. Im doing my cam and heads right now so the tune is already a must.
Thanks for your help.
Old Aug 10, 2009 | 10:32 AM
I8ASaleen's Avatar
I'd definitely go higher on the fuel pump after seeing your setup in the sig. Even with a new fuel pump you'd be pushing it with a cam and nitrous.
Old Aug 10, 2009 | 12:26 PM
litch2004's Avatar
ya i plan on changing it anyways just for the security of the matter.
