brake question - need to pump a few times..
so i got the car back together a few weeks ago and just working on the small stuff to get it driveable and buttoning everything up. I eliminated tcs/abs and have the sjm kit installed. i bent some new lines for the front brakes and the rear lines are stock. after bleeding it, i noticed the pedal to be really soft and sinking straight to the floor. i looked and saw what looked like a leaking master cylinder so i said screw it, go out and get a new one from advanced auto for 75. the original has been in there 13 years already, figured it was time. I bench bleed the new master cylinder and get it back on, then proceed to bleed the brakes again (furthest from the cylinder) and lo and behold, the pedal pressure is a bit better, but i still have to pump it twice to stop the car. the first time it goes down with some resistance and the second time it will stop it. I'm a little stumped as to what to do next. we took the wheels off thinking we needed to bleed some more, but we're not getting even the tiniest bubbles out. then I start thinking could the proportioning valve need to be bled too, what about the linelock? i don't have power going to the line lock yet, i'm assuming it doesn't need it for the brakes to work. any thoughts? stumped on a saturday afternoon is a bummer...not finding much via search either, hoping i'm missing something obvious.
