Timing chain without pump drive
Old Aug 10, 2009 | 11:15 PM
1bad72's Avatar
Default Timing chain without pump drive
Rebuilding my engine and need to find a part# for the timing set everyone was using that had a Ewp. I took my waterpump drive out and pluged the hole. Also looking for cam sugestions For mild street car. Hot cam?
Old Aug 10, 2009 | 11:21 PM
buckner163's Avatar
I went back with a stock LT4 chain but many go with the cloyes or extreme duty.
As for cam, get ready.....you're gonna hear alot of opinions on this issue.
IMO, if all you want is a nice little bump in power and you're not trying to squeeze every last bit of HP out of it then the HC is an ok choice for a budget concious individual.
Old Aug 11, 2009 | 02:13 AM
ss.slp.ls1's Avatar
Cloyes 3145 DR timing set. You can get them from Summit.
Old Aug 11, 2009 | 02:29 AM
enjoi355's Avatar
does any tc work as long as its meant for an oe roller cam block??
Old Aug 11, 2009 | 07:51 AM
monster81's Avatar
it should work
Old Aug 11, 2009 | 07:47 PM
1bad72's Avatar
Thanks for the info. Anyone with a hot cam kit have Et's from the track. What kinda of times can I expect?
Old Aug 12, 2009 | 06:29 PM
buckner163's Avatar
Mine is a hotcammed car but its a factory LT4. Headers, pcmforless tune, 4.10s and 3250lbs. 12.30s at 115mph
'most' F bods run 110-112mph with the hotcam from what I have seen but that varies depending on stock/ported heads, other mods.
