Head gasket question
Old Aug 14, 2009 | 12:01 PM
ss.slp.ls1's Avatar
Originally Posted by fleetmgr
If you have a bad head gasket, you'll have your leakdown test leak into the cooling system.
Then the test will show a problem, and the only way to fix it is to pull the head. And bingo, you should notice your blown head gasket.
Old Aug 14, 2009 | 03:02 PM
nalmak's Avatar
You need to define "high in the temps".
Redline. The highest the temp gauge will go.
Old Aug 14, 2009 | 03:03 PM
nalmak's Avatar
Originally Posted by ss.slp.ls1
Just so you know Nalmak, LT1's run hotter than LS1's. It's completely normal to have it sit at about 1/4 mark on the freeway and then when you come to a stop it will gradually rise and teeter around 210-230*. That's normal.
Oh Ok. Then it still does that. Then I'm good.
Old Aug 14, 2009 | 08:37 PM
96blackta's Avatar
Eh, still that's pretty hot. I would do a coolant flush and see what kind of gunk comes out. Make sure you've got a 50/50 coolant & water ratio too.
Old Aug 14, 2009 | 09:00 PM
nalmak's Avatar
Yeah will do tomm.
Old Aug 15, 2009 | 07:28 PM
nalmak's Avatar
Still does the same thing. But at least a bit better.
Old Aug 15, 2009 | 09:05 PM
ss.slp.ls1's Avatar
Same thing? You mean going to ~210-230 and staying there and dropping down to 1/4 on the freeway...I told you that was normal.
Old Aug 16, 2009 | 12:21 PM
nalmak's Avatar
Yeah its doing that. It dosen't go into the red anymore. Now I gotta think of ways to mod it. This seems harder than the LS1. Am I right?
Old Aug 17, 2009 | 10:58 AM
ss.slp.ls1's Avatar
I can tell you exactly what you need including part numbers and cost to make that thing fast.
Old Aug 17, 2009 | 12:31 PM
nalmak's Avatar
Please do PM me.
Old Aug 17, 2009 | 02:20 PM
ss.slp.ls1's Avatar
Please do PM me.
PM sent
Old Aug 17, 2009 | 04:58 PM
  #32
djjab57's Avatar
DAMN How long did it run that hot ? You might need to get your heads milled now could possibly be warped now !
