Head Porting - DIY
Old Aug 13, 2009 | 10:22 AM
ADM's Avatar
ADM
You haven't stolen the thread. You are posting very useful information that everyone can make use of.
Thanks for the links man, I'll read through them.
Old Aug 13, 2009 | 10:26 AM
ADM's Avatar
ADM
I have seen all these bits at a DIY store here. I will need to get me a decent straight electric drill tool to use with variable speeds.
I won't remove the heads just yet, first get the tools, head gaskets and ARP bolts and then I will start work. Will let you guys know how it works.
Old Aug 13, 2009 | 11:24 AM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
to bad your on the other side of the damn planet or id let you use all my ****. lol
Old Aug 13, 2009 | 12:02 PM
litch2004's Avatar
HAHA i know what you mean there. I still live in southeast texas and my family lives in bahrain.
Old Aug 13, 2009 | 12:55 PM
i almost got a job over in Bahrain. i was actually pretty excited to go. Military pays good when you go over seas lol
Old Aug 13, 2009 | 01:20 PM
ADM's Avatar
ADM
Life here is quiet and simple. But the police are really onto us, they are everywhere pulling you over for just about anything. The main victims, thankfully, are the Honda boys haha
Old Aug 13, 2009 | 01:22 PM
Geneticallybroke's Avatar
http://www.gofastnews.com/board/tech...trictions.html
look over as much info as possible
Old Aug 13, 2009 | 01:31 PM
NemeSS's Avatar
a basic vj with a backcut and cleanup of the bowl will improve low-mid lift flow. for basic bolt ons car, a basic gasket match will also help overall
Old Aug 13, 2009 | 07:33 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
There's some decent links in here. Vizard is usually pretty accurate with his information. Search on here and some other sites around the internet and you should get a general outline of how things work. Speedtalk is a very good technical source of information.
Old Aug 14, 2009 | 11:42 AM
Mikey 97Z M6's Avatar
Here's a link to a write-up I did on LT1 heads about 9 years ago. This isn't my website, but they are my heads/pics/write-up info. There's probably better info out there these days but maybe you can get something out of it. The pictures show red "x's" but they'll pop up if you click on them. Also, you have to click on "head porting" on the left to access the write-up.
http://members.***.net/gmarengo/
Mike
Old Aug 14, 2009 | 11:51 AM
ADM's Avatar
ADM
Thanks bro, thanks everyone for helping out.
I don't usually take pictures of my work, but I will try to make a progress thread with all the work.
Could you help me out with a list of the tools you used? What stones and bits?
Old Aug 14, 2009 | 12:10 PM
  #32
Here's a link to the 5.3l LS heads I ported. The first couple pics shows the die-grinders and bits/burs/cartridge rolls I use when porting heads. I prefer pneaumatic die grinders because I can switch to another grinder very quickly and easily, which saves alot of time.
https://ls1tech.com/forums/generatio...6k-beware.html
Mike
Old Aug 14, 2009 | 03:56 PM
  #33
SoxXpupPeT's Avatar
Thats really good work. What gaskets did you use for the intake and exhaust?
I ordered http://www.summitracing.com/parts/PHP-66031/ for the headers and http://www.summitracing.com/parts/FEL-MS95580/ for the intake.
yeah those are the same gaskets im running. those exhaust gaskets are really nice! no leaks at all! i had used a straight 1/4" air die grinder and 2 small carbide die grinding bits. the one i felt most comfortable with was like this
Old Sep 14, 2009 | 03:58 AM
  #34
ADM's Avatar
ADM
Just bringing this thread back to life. I did a couple of intake ports lastnight. I just blended the dividers straight, removed the steps at the edges, and the big beafy parts I blended back and squared with the gasket but I maintained the curve for the airflow.
I am just doing a clean up, nothing too radical because I don't know the limits of how much I can remove.
Will try to post some pics later today.
Old Sep 14, 2009 | 04:03 PM
  #35
ADM's Avatar
ADM
I have a feeling I am doing something wrong with the outer walls of the parts, like they should rather be straight instead of curved?
Please excuse the photo quality, will try to get better ones.
Old Sep 14, 2009 | 05:38 PM
  #36
ADM's Avatar
ADM
Any input guys?
Old Sep 14, 2009 | 07:03 PM
  #37
A20SVT00's Avatar
looks good keep it up
Old Sep 15, 2009 | 01:11 AM
  #38
in my opinion i would just work on the inside of the ports with the grinder. untill its flat and smoooth. or just leave it and make sure its smooth
Old Sep 15, 2009 | 11:51 AM
  #39
ADM's Avatar
ADM
The inside walls are already dead straight, they just need some polishing to remove the roughness of the cast and any flashes.
I am more concerned about the outer walls of the ports.
Old Sep 15, 2009 | 02:13 PM
  #40
pancherj's Avatar
The outer walls of the port are not as high flowing an area as the inside walls (at least near the intake face and down to the valve guide). Also, the tops of the port see more air than the floors. You also want to widen the port on either side of the valve guide boss (smooth the boss down some) to give the air enough room as it navigates around the valve stem and the guide boss. The area under the valves (valve throat) should be about 80% the size of the valve. For a typical street motor, you will see the biggest impact from
1) Valve Job
2) blending valve job into chamber and unshrouding the valve at the chamber wall
3) Bowl area (directly under the valve)
4) Valve guide area and short turn (the floor as it turns into the bowl)
5) Lastly, the pushrod pinch point
I have only done a few sets of heads and never any LT stuff. I rely on David Vizard books. He has a really good one on modifying small block chevy cylinder heads. Lots of really good illustrations of port shapes (you may be able to find those pictures on the internet). Pick it up if you can!
