58mm throttle body.
Old Nov 22, 2003 | 02:20 PM
kevsbird's Avatar
Default 58mm throttle body.
I have a 58mm tb, and a TnT F2 plate. the two of the will not fit on my 94 LT1. what do I have to modify to get them to fit?
thanks
kevin
Old Nov 26, 2003 | 03:12 PM
flyinZ's Avatar
I would call TnT, and ask them...They should be able to help you.
Old Nov 26, 2003 | 03:51 PM
ChrisB's Avatar
I had a compucar plate for awhile. I had to grind down on the TPS motor housing on the bottom of the TB and the thermostat neck for the waterpump.
Old Dec 2, 2003 | 07:31 PM
Scott96LT1's Avatar
Not sure about the plate but you'll need to bore out the intake to 58mm for the TB.
Old Dec 16, 2003 | 04:48 PM
kevsbird's Avatar
I deleted the iac. drilled and tapped the holes underneath the t/b. the idle is fine, and the engine revs up and down like a carb'ed car.
Old Dec 20, 2003 | 01:17 AM
ex-SS-ve's Avatar
just installed a holley 58mm tb on mine.. only probs i have is when i romp it while im rowin thru the gears is the ses light coming on.. my guess is its freaking out the maf under w.o.t.. i never bored out the intake for the 58 mm tho.but i got a spare intake layin here that ill be doing that to..
