Mallory Hyfire Questions. 2-step?
Not quite the same but close. I set the Mallory 685 box 2-step to enable when I flip a toggle switch, then when I stage and press the brake pedal, a signal goes thru the toggle switch (which get's it's power from the brake light)into the 685 box's 2 step wire. This allows me to run the rpm up to what the 2 step is set for. Let off the brake and take off. A line lock won't hold an auto in the staging beams by itself. I use the LL only for burnout. the 2 step just allows me to launch at a consistant rpm.
Yes, it all depends on what your 2-step is set for, and how well your brakes hold. My converter is a Vigilante 3200 and I only set the 2-step for 2500 to get a consistent launch. That's what works best for me.
