Best place to buy Stroker ready blocks?
Old Aug 15, 2009 | 07:37 PM
97Z28SS's Avatar
Try www.cncblocks.com they may be able to help you.
Old Aug 16, 2009 | 12:11 PM
99blancoSS's Avatar
I'll drop our name into the hat. We offer a 408 with your LT1. This is a non power adder engine precision built by HKE. $4550
Old Aug 17, 2009 | 08:24 AM
WS Sick's Avatar
Cap screws require alot more clearance than regular rod bolts.
I have built a few 383s and with just that stroke you need to buy a junk set of bearings because youre going to have it together and apart 50 times before the final assembly.
The easiest kit I put together was one of those cheap hyper piston 5140 rod , cast crank eagle kits , very little trimming, the crank required about 300 $ to balance though (at my cheap Oklahoma prices) that would probably translate to 1000$ in some other state.
Old Oct 2, 2009 | 01:25 PM
Roadwarrior1956's Avatar
These guys built me a 383 motor a year ago, they do excellent work!
http://www.cpengines.com/
Old Oct 2, 2009 | 04:49 PM
Corey @ Clayton Racing's Avatar
Depends on which scat rod you have, we stock them and the cranks, we could clearance a block for your setup since I have them on the shelf to use for fitment. But everyone is correct you want to fit the pieces to the block, in other words you dont want to take to much material out because there is a water jacket there. Shoot me a PM or call me if you want to discuss it.
