95 lt1 swap
Old Aug 15, 2009 | 07:40 AM
tbroom1's Avatar
Default 95 lt1 swap
I got a LT1 from a 95 Z28 Going into a 86 Monte Carlo which had a 305 in it. This is my first LT1. I also have the 4L60E tranny with all the wiring for the engine and tranny. What I need to know is.
1. Can I use my radiator or need a new one.
2. Can I use a inline electric fuel pump or replace mine gas tank with a pump installed tank.
3. Will the MC motor mounts work.
There more question but you kinda see where I`m going. I trying to eliminate as much time as possible cause I have my brother on my *** about taking up space in his garage. Any help on this will be appreciated. Thanks
Old Aug 15, 2009 | 08:31 AM
monster81's Avatar
since the LT1 has a reverse flow cooling system, guess u will need a LT1 radiator as well
Old Aug 15, 2009 | 12:08 PM
92camaroguy's Avatar
1. I used my radiator on my 3rd gen f-body for my swap works fine not sure if the MC is a whole lot diffirent.
2. I would get a tank off a 4.3 MC they are set up with the high pressure fule pump. (might want to run new fule lines)
3.The LT1 mounts are no diffirent than a GEN 1 sbc.
You could probbaly google it I am sure you will get more direct info on what has to be done.
Old Aug 16, 2009 | 09:17 AM
tbroom1's Avatar
OK, Great info would I need to upgrade the rearend
