need help lt1 camaro front mount turbo
i have a 97 lt1 camaro im about to start putting a front mount turbo on this weekend.im using stock manifolds anyone have any pointers on where to put turbo. what piping size. its a t3 turbo, i have everything needed except the piping. do i have to run oil line to the oil pan or can i tap into oil cap ? i could use pics thanks for the help in advance. i did do as much searching as i could just want a lil extra info that would be easier for me to find my email is e.tucker93@yahoo.com if u want to send pics
Get a book called "Maximum Boost" by Corky Bell and read it before you start.
That will help you out a lot on sizing the charger. It really depends on if it will be a street or track only car as to the size of charger you run, what exhaust housing, etc...
You can get a setup that won't spool for **** on the street so it's no fun to drive, or you can have near instant spool up but choke it out on the topend.
Get with someone who has experience doing it on these types of engines and let them help you spec a charger, as long as gaining some understanding of whats going on for yourself.
