1st fire up after cam swap
. Point being, none of the rockers are supposed to be loose... So just keep bumping the motor over and adjusting until the slack is all out of them, and run it for a few minutes, the adjust them again. If that doesnt work then sounds like you are off a tooth on your timing gear.
A PCM tune will cure this, but unless or until you have it done, you'll probably have to manually raise the idle RPMs. How much depends on the cam and other engine mods, but somewhere in the range of 850 RPMs should work to keep the engine running in gear, foot on brake conditions.
In the past I've just folded a piece of a match book cover (paper) or something similar and placed it at the throttle body lever to keep the idle UP as a temporary way to keep the engine running while it warms up.
WATCH YOUR OIL PRESSURE AND COOLANT TEMPERATURE LIKE A HAWK!
Jake
West Point ROCKS!
If BOTH dots were at the 12 o'clock position, then the dowel pin should have been at the 9 o'clock position.
As long as you selected the correct hole in the OPTI for the dowel pin, you're good to go. If the OPTI had been incorrectly installed the engine would either NOT run at all or BACK-FIRE like crazy; most likely the former.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
I'm stumped again.. this makes no sense! I had a plug wire that wasn't quite on all the way so I fixed that and now it won't fire up again! it just cranks the then when I stop cranking it it will turn over a few more times.
do I have these grounds right? if its hard to tell I put the double one on first then the single one. I also pulled that pig tail back out because its was suspected to be for the AIR pump but never positively confirmed.
I triple checked the wire connections and order. ...don't know what else to do
BECAUSE when the intake rocker closes the piston is still at the bottom of the stroke. obviously you dont want the piston to push the air/gas out of the engine. So when you tried the other method of putting your finger in the hole you actually found TDC at the right time which would put your mark at 9 when it shouldve been at 12.
make sense??
make sense??
he has the same type of tube coming out the bottom nipple as he does the top one while I have a rubber hose going into it from the EVAP solenoid, which I had asked about earlier on and got this answer>
http://shbox.com/1/evap_sol.jpg
it says the bottom nipple plugs into the plastic line bundled w/ the fuel lines..but that goes to the evap solenoid.. I wouldn't suspect this is actually the root of my problems, but I'm running out of ideas.
the vent line is literally a 1in piece of hose w/ a 90* bend. it doesnt connect to anyhting. It really isnt anything to worry about. What do you mean the bottom port on the intake? do you mean on the throttle body? if thats the case you have it on the wrong one. the bottom port is for the coolant that flows through the throttle. i believe you did the bypass so that will just remain un-pluggled.
you need the evap hose connected to the middle port. the top one is for that tube that connects to the top of the valve cover
As I wrote before, using the method that most, if not all, of the cam companies, Tech writers, PROs, etc., use on Chevy engines does NOT involve anything dealing with TDC.
Also, it doesn't involve setting the preload on one lifter on the driver's side then going over to the other side of the engine to set one over there.
Haven't you ever watched the guys with REALLY fast cars go through their valves between rounds at the track? Yes, they're setting LASH not preload, but the the procedure is the same. Watch the intake to set the exhaust, then watch the exhaust to set the intake. The IC/EO method.
I've tried to help, but it seems you've chosen your own, different method. Sorry, I've done the best I can do, so I'll just leave it for you and the other members to work out.
"Lead a horse to water but can't make it drink" comes to mind.
Good Luck to you.
Jake
West Point ROCKS!
Good Luck to you.
Jake
West Point ROCKS!
edit:some one else asked me to make another vid while tryin to rev it up, I was hitting the gas the entire video and it still stalled on me, also it only revved to 1k for a few seconds on the 2nd start up while having my foot to the floor.
